Fan clutch?
Old Jun 14, 2012 | 06:53 PM
mudguts's Avatar
mudguts
Fan clutch?
I'm pretty sure That my fan clutch is on the way out, I have replaced thermostat, water pump, radiator, heater core, hose's and belt's, sending unit to gauge, now over the last 2 day's my temp gauge read's on the N of normal for a awhile then goes up in between the R&M of normal, then back down to the N.( all during a 200 mile trip) when the engine is cold and I spin the fan by hand before I ever start the engine, I can sometime's feel more resitance than other's. since this is a new engine, I dont want to take any chance's. any input would be greatly appreciated. Thank's MudGuts. also not losing any coolant.
Old Jun 14, 2012 | 08:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Post Engine cooling fan clutch test
Originally Posted by Dave Sponaugle
Here it is, kinda long.
The purpose of this procedure is to determine whether the fan clutch is functioning properly, or to determine if the clutch is not engaging, not disengaging, or causing vibration. Worn or damaged cooling fan clutches should be replaced with the proper service part. Do not attempt to modify the bi-metallic coil on the face of the fan clutch.
Locate a piece of cardboard large enough to cover the front of the radiator and an engine tachometer before proceeding with this diagnostic test.
1. Turn off air conditioner, heater - A/C fan, radio and any other accessories.
2. Before starting the engine, rotate the fan by hand. It should have some viscous drag, but it should turn smoothly during the full 360 degrees of rotation. The fan clutch should be replaced if it does not turn smoothly, or if it does not turn at all. If the fan clutch spins with no viscous drag when it is cold, and has not been run for an hour or more, it should be replaced.
3.To check for excessive fan clutch bearing clearance (cold fan clutch), hold the tip of the fan blade between the thumb and forefinger and lightly pull toward the radiator, then push toward the engine, repeating the motion several times. The total rocking movement at the end of the blade should be 5 mm (2/10") or less when no more than 8 ounces of force is applied. A force greater than eight ounces may deflect the blade and give erroneous results. Replace the fan clutch if more than 5 mm (2/10") of movement is observed.
4. Install a temporary engine tachometer if the vehicle is not equipped with a tachometer.
5. During the following tests, be sure to monitor the coolant temperature (temperature gauge in the instrument cluster) and shut off the engine if the temperature rises above the maximum recommended limit for the engine, or if coolant is discharged outside the system. The tests can be resumed using the following procedures after the coolant temp drops off to a normal operating level.
6. If the hood is left open, the fan noise may be easier to hear.
7. Start the engine. The fan clutch may be engaged when the engine is first started. This will be apparent from the noise level which has a distinctive roar. The fan clutch engagement is due to the viscous silicone fluid draining back and filling the gap between the input and output components. Running the engine at a consistent speed of about 2000 RPM should pump the fluid back to it's reservoir, disengaging the fan clutch after no more than five minutes. As the fan speed drops declines, the noise will drop off to a level inaudible to most observers. If the fan does not disengage after five minutes at 2000 RPM, the fan clutch should be replaced.
8. Stop the engine. Cut and install a piece of cardboard large enough to cover the front of the radiator with a 6" diameter hole in line with the fan clutch. If it is not possible to install the cardboard directly against the radiator, attach it to the A/C condenser.
9. Start the engine. With a gasoline engine at 2700 to 3000 RPM or a diesel at 2100 to 2300 RPM, the vehicle coolant temperature gauge will rise at a steadily as the engine warms, then appear to level off for a short time when the thermostat opens. Make a note of the temperature gauge position when the thermostat opens. The engine coolant temperature will continue to rise until the fan clutch engages.
10. Continue to observe the coolant temperature gauge. As the fan clutch engages the fan noise will continue to increase and then level off at full engagement. The fan may cycle off and on during the initial engagement. If the fan does not engage before the maximum safe operating temp is reached, it should be replaced.
11. After completion of the above tests, shut off the engine. Remove the cardboard cover from the front of the radiator. Restart and return the gas engine to 2700 to 3000 RPM or the diesel to 2100 to 2300 RPM, continuing to watch the coolant temperature which will begin to decrease. The fan RPM will drop to a reduced noise level where it was before the cycle began which indicates the fan clutch has disengaged. If the fan clutch remains engaged and the coolant temp has dropped below the thermostat opening temperature for at least five minutes, the fan clutch should be replaced.
12. If the fan clutch is replaced for any of the above test steps, the test should be repeated to verify the fix and owner satisfaction.
installing a real gauge is always a good idea too.
in step 10 there,posted by Dave:
"If the fan does not engage before the maximum safe operating temp is reached, it should be replaced."
the max "safe" temp for the idi diesel engine is 237 degree's. 240 or less,your good to go though.if she climbs up over that,your best bet is to just shut her right down and let it cool for a while,if you can't find a crawl speed/real low load (with heater on full in the cab,with blower on high) yet still decent air flow to lower it quickly,so you can ease on home.always remember a tow is much cheaper and a lot less hassle than an engine replacement.
did you know these fan clutches have a VERY high failure rate?
the ford 3.8l engines with e-fans do not,fyi.
Old Jun 14, 2012 | 08:45 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Im with you mud, mine lacks that "distinctive roar" lol... Granted everyone once in while it will kick in... but i dont like not overheating every once in a while. However im hoping to go the way of the E-fan.
Old Jun 14, 2012 | 08:48 PM
Aune163rd's Avatar
Aune163rd
BAH! I have never replaced a fan clutch nor have I ever heard mine lockup except the 84 engine when climbing 3 passes with the engien pulling a total of 20k lbs!
Old Jun 15, 2012 | 03:38 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I love my fan clutch, when that sucker locks in, it ROARS...like a Boss
Old Jun 15, 2012 | 04:37 PM
FORDF250HDXLT
and robs engine hp,so you slow down to a crawl going uphill,requiring even longer duration for the hog to be engaged due to less airflow through the rad cus your moving slower.
glad you love it instead of me lol.
just do me a favor,puller over good so i can zip up by ya.
Old Jun 17, 2012 | 11:53 AM
IDIDieselJohn
How bout you hook up and give me a push?
Fordenthusiasts
19
Aug 15, 2025 04:09 AM
ScaldedDog
May 27, 2013 11:46 AM
TEX250
19
Oct 2, 2007 09:36 PM
rkersh409
Jul 2, 2005 09:05 AM
jetwrench
Jul 15, 2004 08:48 AM
