Steering Column Problems
Old Jun 13, 2012 | 10:37 PM
IZZYAZ's Avatar
IZZYAZ
Finally getting back to working/cruising around in my 1974 F100 4x4 auto. So I pulled it into the garage and put it into park and it didn't shift into park. The shift collar broke inside. Didn't think much of it. I had another column sitting on the shelf. Thought that since I had it out I would rebuild it. When I took the spare one apart the shift collar in that one was also about to break. So I figured I would just replace the collar. I went on line and bought a cheap chinese made one. I went to put it together and it didn't fit. It needs some trimming/sanding to work. In the mean time I bumped the little tab on the bottom side of the column and broke off that controls the neutral safety switch.
So getting to my question, can this tab be replaced? If not can the truck be started with out this tab in place? I have checked around local yards and if they have a column they want $150 or more and I have no idea if it's any better then the one ithat am replacing. Looking for some suggestions, thanks!
Old Jun 13, 2012 | 11:05 PM
nitro_rat's Avatar
nitro_rat
Ididit makes a nice column for our trucks. Pricey though. I got a column from another member in Missouri for my build. It's going to need some work too. I'll detail that when I start working on it. I'm not familiar with the guts for these columns - yet. I can build GM tilt columns from parts though.
Just keep looking, and you'll find what you need!
Old Jun 13, 2012 | 11:09 PM
gpence's Avatar
gpence
I have a 76 non-tilt with a grant style steering wheel on it sitting here. I was asking $50 on it. I don't know just how far from me Story IA is (I'm in NE just outside of Lincoln) but figured I'd throw it out their at ya
Old Jun 14, 2012 | 09:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by IZZYAZ
Finally getting back to working/cruising around in my 1974 F100 4x4 auto. So I pulled it into the garage and put it into park and it didn't shift into park. The shift collar broke inside. I went on line and bought a cheap chinese made one. I went to put it together and it didn't fit. It needs some trimming/sanding to work.
In the mean time I bumped the little tab (NSS Selector Lever) broke off that controls the neutral safety switch.
D5TZ-7228-A (replaced C9TZ-7228-A & C5TZ-7228-A) .. A/T Shift Collar / Available from Ford
Applications: 1965/66 F100/250 / 1967/77 F100/350 / 1973/77 Bronco.
MSRP: $65.98 // FTE sponsor tousleyfordparts.com price: $43.55.
DOTZ-7B097-B (replaced DOTZ-7B097-A & C5TZ-7B097-A) .. NSS Selector Lever / Obsolete
Applications: 1965/77 F100/350.
HAWKEYE FORD in Red Oak IA has 1 = 712-623-5147.
ALBIA MOTOR CO. in Albia IA has 1 = 641-932-5416.
KLIMESH MOTOR SALES in Calmar IA has 2 = 563-562-3241.
FREESE MOTORS in Monticello IA has 7 = 319-465-3541.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3,044 (!) = 800-476-9653.
Old Jun 14, 2012 | 09:14 AM
84espy's Avatar
84espy
Your short answer is yes the switch can be bypassed. Just don't do it for long, as it is a safety feature.
Old Jun 14, 2012 | 10:05 AM
Aaron-71's Avatar
Aaron-71
2X...
I have bi-passed it before just to travel a very short distance (less than a mile), but don't keep it that way.
The NSS is a very important safety feature on these old trucks and shouldn't be tampered with.
IF you have to, electrical tape everything together until you can find a new column or can save up the pennies to do so.
Old Jun 15, 2012 | 06:22 AM
bamaf150's Avatar
bamaf150
I think I know the answer but did the manual tranny equipped trucks have a NSS?
Old Jun 15, 2012 | 07:45 AM
Raptor119's Avatar
Raptor119
I do not think a NSS was installed on manual tranny trucks in 73-79. Later trucks had the switch on the clutch pedal but I am pretty sure they had nothing in 73-79.
Old Jun 15, 2012 | 09:03 AM
NumberDummy
The OP has an A/T, my response (post #4) was related to it.
The NSS is on the column 1965/77, on the trans 1978/79 // 1967/77: The switch is the same C4/C6/MX/FMX: C7TZ-7A247-A (Motorcraft SW-600).
1978/79 C6 uses a different NSS (D8TZ-7A247-A (Motorcraft SW-1489), than a C4 (D8TZ-7A247-B (Motorcraft SW-1491).
Beginning in 1984, F150/350's & Bronco's have an interlock switch mounted on the clutch pedal. The clutch must be depressed to start the vehicle.
Old Jun 19, 2012 | 07:49 PM
IZZYAZ's Avatar
IZZYAZ
Thanks again NumberDummy for the help. I was driving thru Albia IA today stopped bt the tiny Ford dealer there and got the NSS switch. I gave the 20 something year old kid the number of the part and he says it looks like we have it. 2 minutes later he comes walking up to the counter with a little blue and white box with an inch of dust on it. Opened it up and there it be. Local dealer order the shift collar for me at the reduced price. I had to do a lot of whining but didn't have to pay the $70 retail.
joecope988
Dec 19, 2018 09:55 PM
daveinva
Nov 30, 2018 04:30 PM
Little Wolf
Nov 28, 2011 04:04 AM
RJP66F100
18
Aug 7, 2010 10:36 PM
big ronnie herr
Aug 21, 2008 12:36 AM
