rough idle
Old Jun 12, 2012 | 11:13 PM
fordnurse's Avatar
fordnurse
rough idle
I jumped in my truck this morning and drove it around and had no issues. A little while later I got back in and the first light I came to it idled very rough. I could put in neutral and it would get better but its been fine prior to today. I had the carb rebuilt this past winter. 351m....I even adjusted the fuel mixture screws because it had more of a gassy smell from the exhaust thinking it was too rich but it didn't do anything...so I returned them to their original setting and had to idle the truck up to get it to run better but its high. Its not misfiring and I hear no vacuum leaks under the hood. I checked the distributor and its not loose so I don't think the timing changed..what could it be? I am assuming there is something wrong with the carb?
Old Jun 13, 2012 | 06:28 AM
fmc400's Avatar
fmc400
MSEE
You can't always diagnose vacuum leaks by sound; also the proper way to adjust the idle mixture is with a vacuum gauge.
I'd start by reinvestigating those two.
Old Jun 13, 2012 | 07:40 AM
northerndave's Avatar
northerndave
How many turns out are your idle mixture screws? 5 to 7 seems normal in my experience with these 351M/400 engines.
If it seams to be loading up at idle, I guess I'd suspect the power valve. Power valve is hidden under a square cap retained by 4 screws on the front bottom side of the carb. Power valve is a vacuum operated diaphragm valve that opens the flow of fuel from the float bowl to the carb throat when the engine is under heavy load. There is a tiny vacuum port in the carb body that controls this diaphragm. The diaphragm becomes cracked over time and then gas gravity feeds through the diaphragm and through that tiny vacuum port which feeds it directly into your engine. It's like having a 3rd idle mixture port open feeding extra fuel into the engine.
If the crack gets bad enough it will drain your float bowl into the engine while sitting and it will also fail to open the power valve on acceleration, you might experience a "lean pop" backfire with your foot in the gas and the truck under a load.
Old Jun 13, 2012 | 07:57 PM
fmc400's Avatar
fmc400
MSEE
If you have to have your screws out that far; you've got a vacuum leak. Should be no more than 2 turns.
Old Jun 13, 2012 | 09:20 PM
northerndave
Lol!!
I've never seen one of these 400's or 351M's run at 2 turns.
Old Jun 13, 2012 | 09:21 PM
fmc400's Avatar
fmc400
MSEE
Not sure what to tell you, other than none of the ones you've seen have been in working order.
Old Jun 13, 2012 | 09:32 PM
ctubutis's Avatar
ctubutis
I've got a 400 M-block, I think they're at 3/4 turns. Five to seven == something is wrong there.
Old Jun 13, 2012 | 09:38 PM
northerndave
They must work different in TX
My 77 F250 351M manual trans, 6 turns each. My 77 F150 351M C6, 6.25 turns.
A previous truck, 78 F150 400/C6... complete rebuild, fresh as a daisy, 7 turns each.
Those all wear motorcraft 2V original carbs.
My 70 F250 with 360/4spd is at 1 3/4 turns (holley 600 cfm sq bore 4 barrel, vac secondaries.)
Old Jun 13, 2012 | 09:43 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
I think it really depends on what carb is being used to determine how many turns of the idle/air screw. With a 2bbl on a V8 I had 4 half turns and a 4 bbl I had 2 half turns. My 300 has a 1bbl and I have it a little more than 2 half turns. It also depends on your initial timing an Idle. More timing means you need more fuel to keep the engine from runnin lean. The more the timing is advanced you may have more troubles with rough idle and over heating.
Old Jun 13, 2012 | 09:53 PM
PRIMERED79 SHORT BED's Avatar
I have a 400 with a rebuilt 2150 and i have my screws around 4 turns out.
That's with a idle at 700rpm and vacuum holding pretty steady at 19hg.
Old Jun 13, 2012 | 09:55 PM
northerndave
I know that on a motorcraft 2V if you can turn the idle mixture screws in all the way and the truck keeps running... your power valve diaphragm is cracked.
Old Jun 13, 2012 | 10:01 PM
northerndave
My edelbrock and holley 4 barrels on these same engines run great at 1.5-2.25 turns average, I don't know why I have to spin my mixture screws out so far on my 2100's... I just figured it was the needle profile being "sharper", less blunt.
I know I don't have vauum leaks.
Old Jun 14, 2012 | 08:39 AM
fordnurse's Avatar
fordnurse
Ok so I don't know enough to diagnosis all this stuff myself so I took it to a local auto shop...they had to replace my power valve and they found two vacuum leaks..but its still not driving quite right..its A LOT better don't get me wrong but there something missing...
It stills seems like the idle is off..almost like the idleidle changes while sitting at a light..that and when I start from a dead start it hesitates to move like the tranny hasn't engaged but hasn't doesn't this before and doesn't do it every time...is this a completely different issue or could one have exacerbated the other?
Btw I haven't paid for services rendered yet at shop...he wanted me to drive around and see it how it went
Old Jun 14, 2012 | 09:16 AM
bamaf150's Avatar
bamaf150
Sounds like a respectable shop. Tell him all this and get him to ride with you, get his opinion. Did he put a timing light on it? Maybe it needs retiming after this work.
Old Jun 14, 2012 | 09:37 AM
ctubutis's Avatar
ctubutis
I wonder if the idle speed is too low, and/or the transmission needs fluid.
That's a good shop, I like them! See if you can drive around with one of their guys in the truck with you so you can SHOW them what you're seeing. Trying to describe stuff like this in written format can be really hard to do, so, show them....
