My heads are cracked, help me select new cylinder heads
I agree that displacement makes torque but I wanted to better understand camshaft and cylinder combinations. I already overhauled my short block and had it apart two times. I would love to build a 434W but this time around I overhauled a running 351W while improving breathing. I actually enjoyed the torque of the engine. I have been reading lots of engine builds and trying to decipher the build's effects on the torque curve.
I have seen trad-offs in torque such as more low end torque in the superficial end of the torque curve or outside the better part of the torque curve, vs. the same engine with more torque in the better part of the torque curve with a small sacrafice in low end torque in the superficial part of the torque curve, outside of the better part of the torque curve. That is what a loose torque converter is for.
What are appropriate camshaft and cylinder head combinations? I would like to compare 180cc and 200 cc on a 351W.
I wouldn't expect a 190 @ .050" camshaft to be ideal here but would a 230 @ .050" kill my torque curve? Would a 210 or 220 @ .050" build more torque and/or a wider torque curve?
In the 383 build article, the 180 cylinder head made the most low end torque while the 215 made the most horsepower and only sacraficed a small amount of low end torque. The 230 head killed the torque curve and made less horsepower than the 215. The 200 was reasoned to make the best torque curve but it was close between the 200 and 215 cc cylinder heads.
Here is where I am critical. I don't want to narrow my torque curve or sacrafice mid-range torque for a superficial amount of low end or top end gain.
on
And the same goes for heads, with 351odd cubic inches under them you see increases in both TQ and HP all the way up to the 230-250cfm level, and after that the results start favoring high rpm horsepower.. though the negative impacts on low rpm TQ aren't as significant as it is with cams. But still if you're not going to configure the motor for big topend numbers then why spend more money on bigger more expensive heads. I'm sure that's what baddad is saying when suggesting GT40 heads and he's got a point, my argument is it might cost $600-800 to get a set of these ready to go so why bother when you can have brand new Dart or RHS heads for a couple hundred more. Of course if you can score a good set for $300 then it's a no brainer, these things work much better than any of the stock heads so you'll probably be happy with the results.
I'm getting the AFR 185s.
I called AFR and spoke with a technical represenative. The 165cc cylinder heads are for 289/302 on the street. The 185cc cylinder heads are for 350s on the street. If I were racing and needed the torque curve to extend beyond 6,000 rpm then the AFR 205s on a 350 cubic inch V8 would be a match.
I like Detroit iron.
I don't remember hearing if your engine has zero deck. If it does, I'd look for some good quench heads. I have an 86 Mustang with the E6SE heads and they make awesome torque.
On a 351, I'd be looking for C90E, D0AE, or D5AE heads. Especially the D5 heads. Install some Chebby 1.94/1.60 valves and do your porting magic and you're good to go.
Fergetabout shrouding. Ford actually designs some heads to deliberately shroud the valves. They had a patent on that concept. By shrouding the valve, it forces the fuel in the air/fuel mixture toward the center of the cylinder, giving a more even air/fuel mix in the cylinder. Otherwise, you could end up with a mixture that is rich on the intake valve side, and lean on the already hot exhaust valve side.
Those are all great cylinder heads but they are rare.
My camshafit guy at Schneider steered me into Edlebrock Performer/RPM 1.90"/1.60" valve cylinder heads.
If I came across a set of early 351W cylinder heads like you listed I would likely buy them.
My block has been decked. The previous re-build consisted of running one cylinder head with a few cc more of combustion chamber on the lower deck and smaller combustion chambers on the higher deck. I did not approve of that. I had the block milled straight and for the best consistancy of quench across the cylinders.
I have been playing with small block Fords inconsitatly for about seven years which is not very long. I have com across lots of '60s 289/302 cylinder heads and mostly late model 302 cylinder heads found on 5.0s and 5.8s.
I really like that idea about shrouded intake valves directing the mixture into the middle of the combustion chamber rather than it being mis-guided to the sides.
The concept behind the shrouded valves on the E6 heads wasn't to force the mixture to the center of the cylinder (good luck doing that as you're not dealing with a static environment here with the piston moving down, then back up before the mixture is ignited) it was to force the mixture to swirl as the piston was drawing it into the cylinder, thus getting a better mixture. It worked to a certain extent at low rpms as these engines gave a better torque output at lower rpms than the others. Now the spark plugs in these are located closer to the center of the cylinder, that may be where the confusion about the "center of the cylinder" comes in.
on
I have a set of worked over E6 heads that were on my 5.8 for a while and when I took them off the swirl pattern was clearly visible in tan colored deposits in the combustion chamber. The design works as advertised because that motor made great TQ but even with the ports hogged out as much as I dared it didn't make exceptional HP. The pic below shows the E6 chamber on the right and an E5 on the left which is similar to the E7, the bottom series of pics shows the intake valve at 1/2" lift in both heads and you can clearly see how much more shrowding there is with the E6 design.
If you look at any of the newer performance heads they all have irregularly kidney bean or figure 8 shaped combustion chambers now, they're getting away from the open D chamber which really doesn't do much besides not shrowd the valves. The pic below shows a Dart Iron Eagle with 2.02/1.60 valves on the right next to an E7.
DarkWolf40
11-27-2004 02:14 PM
debestuss
07-21-2004 04:39 PM
