Hp #'s ???????????
Old Feb 27, 2006 | 07:17 PM
yomow's Avatar
yomow
Hp #'s ???????????
Could any one run Hp #'s for me . For the following build.--------------------------------------------------------------------------------
Here is my engine 89,302 HO EFI Big Bronco 4x4, ford mass air, mac headers,1.6 roller rockers ford,347 stroker kit installed & balanced,9.2 to1 comp. roller camshaft comp. cams specs. as follows,PART # 35-000-8 FW FORD 351W/302HO HR/SR
CORE C35-8J FW FORD 302 H.O STEEL *** REORDER C35-8I
Special Grind
GRIND # FW 3342B/3343B HR112+3
DURATION @ .050 INTAKE 212 ROCKER
ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 218
INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3010
EXHAUST 1.60
VALVE LIFT INTAKE .480 LOBE LIFT EXHAUST .3010
VALVE LIFT EXHAUST .480 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 109.0
TAPPET LIFT INTAKE 264 CAM ADVANCE 3
TAPPET LIFT EXHAUST 270 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3- RECOMMEND VALE SPRINGS
VALVE OPEN EXHAUST 44 DEPARTMENT P
VALVE CLOSED INTAKE 35
VALVE CLOSED EXHAUST 6- SPC INSTR FOR CUSTOMER
LARGE BASE CIRCLE
1.300-1.350
INTAKE LOBE ID 3342B GRIND INSTR FOR CAM SHOP
EXHAUST LOBE ID 3343B FW 3342B/3343B HR112+3
DATE SETUP 02/11/2003 LARGE BASE CIRCLE
AOD trans., the heads,Intake are stock, what heads & intake do I use street use for pulling a large 20' trl. aprox. 1,700 lbs. Any help needed, I do want to use good head's & intake but use 19 lb. inj. What Hp #'s can I expect ????
Thank's , Don
Old Feb 27, 2006 | 11:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
dimora
176
Apr 26, 2018 08:00 PM
F-250 restorer
Oct 5, 2010 07:24 PM
CowboyFromHell
Apr 22, 2009 11:08 PM
DarkWolf40
Nov 27, 2004 02:14 PM
jwtaylor
36
Dec 23, 2003 09:15 AM
