Alignment
Old Jun 12, 2012 | 11:59 AM
run6.0run's Avatar
run6.0run
Alignment
Anyone know of a reputable alignment shop? And preferably with a contact name...i dont care where at,,, thx in advance
Old Jun 12, 2012 | 12:59 PM
69cj's Avatar
69cj
Dick's Allignment, Riverside, Ca. Very good shop.
Old Jun 12, 2012 | 05:10 PM
run6.0run's Avatar
run6.0run
How many times on how many different vehicles have you used them? I get out there all the time. I just turned 530k mi and have never had an alignment. I think I just need a camber caster adjustment on the passenger side, but dont want to gamble on someone that doesnt know what they are doin... I have gotten over a hundred thousand miles numerous times without rotating or anything on tires on the front. I did ball joints about a hundred thousand ago (without an alignment), and its starting to wear on the outside of the pass tire (only, the other is wearing fine). I'm just giving all this info to explain why I'm being so picky about who messes with it. I would rather leave it until it really needs an alignment, than let some rookie mess it up.
Old Jun 12, 2012 | 05:28 PM
69cj's Avatar
69cj
I've used them a couple of times and a co-worker, very picky to a fault, won't let anyone but them touch his duallys. Sorry had a brain fade. It's Daves allignment. (951)359-1844
Old Jun 15, 2012 | 07:12 AM
Benchwrench's Avatar
Benchwrench
it sounds suspension related again, ie:ball joint
Old Jun 15, 2012 | 07:13 AM
run6.0run's Avatar
run6.0run
Thx for the info cj....i gotta spread some reps first, but then you got some from me...
Old Jun 15, 2012 | 07:16 AM
run6.0run's Avatar
run6.0run
I agree about suspension related...I'm gonna check the adjustment sleeve this weekend...anyone know if they just spin them, or are there different ones that can be put in to change the camber/caster?
Old Jun 15, 2012 | 09:17 AM
Yahiko's Avatar
Yahiko
Tacoma Washington
TINY'S TIRE FACTORY
You want to talk to Rick
I have been going there for more than 35 years
I have used all there services and would recommend them
They work on the larger F-series along with others
10805 Pacific Ave., Tacoma, WA 98444 (253) 531-4535
tinystire@gmail.com
Tiny's Tire Factory :: Tacoma WA Tires & Auto Repair Shop
Sean
Old Jun 15, 2012 | 10:23 AM
BLADE35's Avatar
BLADE35
I with other Guys Probably bad Ball Joint
there isnt much camber adjustment in these trucks and almost by design when you torq the Bolts back up the cam adjuster spins to where it wants to go anyway
I havent taken a Vehicle to get an aligment for Years just use a Tape measure and a few test rides for feel and Bingo
I even got the wife car back in alignment after a wreck and the front tire Broke off
The first time you do it is harder to figure out once you figure 1 then you got it
The Secret is once you get the steering wheel centered back up and it will go straight down the road its aligned
For the Camber its just that sleeve the BJ goes threw and in these trucks it kinda just floats there I guess when you tourque the BJ that may hold it some
Old Jun 15, 2012 | 04:09 PM
strokin83's Avatar
strokin83
Pro Alignment Belton, MO. good people.
Old Jun 15, 2012 | 05:56 PM
69cj's Avatar
69cj
Thanks for the reps.
crandallf150
Aug 14, 2016 10:33 AM
jeffreyclay
Aug 13, 2016 10:04 PM
northerndave
13
Dec 1, 2011 01:04 AM
DCRB
Aerostar
15
Dec 19, 2007 12:19 AM
khilger
Mar 9, 2004 09:43 PM
