brake pedal spring
Old Jun 11, 2012 | 11:14 PM
OregonJen's Avatar
OregonJen
brake pedal spring
Trying to rebuild our brake/clutch pedals on the 47 1 Ton and we're not sure how the brake pedal return spring is supposed to attach. Does anyone have a photo of the set-up? Thanks!! CJC
Old Jun 12, 2012 | 04:54 PM
petey shoes's Avatar
petey shoes
not sure if 1 ton is the same as 1.5 ton? but--click on my name, have some pics at bottom of page. one shows this spring attached to pin in pedal assembly. the other end is hooked on a tab attached to bellhousing. hope this helps.
Old Jun 12, 2012 | 04:58 PM
OregonJen's Avatar
OregonJen
Thanks Petey,
I read through your posts and it appears I don't have the metal tab that was supposed to be on the bell housing. I have a new spring and the proper clevis pin on the brake pedal, just no way to attach the front end. Do you have a picture of the metal tab so I can fab one up (maybe...). Thanks,
Cary
tvliftcabinet
Jun 28, 2017 03:47 PM
zoomeroo
May 3, 2016 02:32 PM
mixup
Jan 11, 2013 06:53 PM
51dueller
Jun 10, 2003 06:56 PM
1949f47
Feb 24, 2003 09:59 PM
