front wipers
Old May 6, 2003 | 07:50 PM
randall5's Avatar
randall5
front wipers
OK, I have read the long post about the wipers which only work on the high speed setting. I only wish that was the problem. Mine don't work at all. I have changed both the motor assembly AND the governor with no luck whatsoever. The fuse (6Amp) is good and the only thing I am left to beleive is that it is electrical. When the wipers are turned on to any setting, I hear one click from the governor, but no successive clicks (for a delay). Any insight that can be provided for my next step would be greatly appreciated.
Randy
Old May 9, 2003 | 07:37 PM
Dough01's Avatar
Dough01
Talking front wipers
Sounds like maybe a faulty switch or a ground problem see if you can check the connector also .Hope It Helps
