sway bar size
Old Jun 11, 2012 | 11:37 AM
driverman1's Avatar
driverman1
sway bar size
Is there anyway to determine front sway bar size other than crawling under with a caliper and measureing it.
Old Jun 11, 2012 | 02:20 PM
alloro's Avatar
alloro
If you had the build sheet for the truck it would be listed on it. But even then, the only way to be 100% positive is to get under there and measure it.
Old Jun 11, 2012 | 02:37 PM
driverman1's Avatar
driverman1
Thanks for the reply. I just went and bought a caliper. I tried measuring it with a tape measure it converted out somewhere between a 33 and a 35 so now I will be more precise.
Old Jun 11, 2012 | 09:52 PM
alloro's Avatar
alloro
For those without a caliper, use an adjustable wrench and snug it down on the bar. When you pull the wrench away, it becomes much easier to measure between the two flats of the wrench instead of trying to measure across a round bar.
Richwon4
All Things Towing
May 6, 2020 08:44 PM
timf150
May 1, 2012 11:13 AM
KenReb
May 4, 2009 10:50 PM
blueeyes2478
Mar 7, 2006 04:41 AM
Mr.Ford 351W
Garage & Workshop
Sep 6, 2005 01:33 AM
