Timing on a 79 400m
Old Jun 11, 2012 | 10:36 AM
0351mike's Avatar
0351mike
Timing on a 79 400m
Hi all
I had a timing question. I have a 79 150 4x4 with a 400m. It was a frame off restoration, but I had purchased the motor from a ford bone yard with a few hundred miles on a rebuild so I do not know much about what went back in. The truck runs pretty well, starts up and idles fine. What has always perplexed me is that when I throw a timing light on it, the mark is no where near the pointer. If looking at the balancer with the light on it- the mark is clear at 6 oclock and the pointer is about 10 oclock while running. I double checked the balancer mark and it is painted at the right spot. Any idea why this thing would run that far off.
Old Jun 11, 2012 | 11:43 AM
northerndave's Avatar
northerndave
Are you clipped to the right spark plug wire with the light?
I'm thinking number one is passenger side front cylinder???
Old Jun 11, 2012 | 01:53 PM
J ballan's Avatar
J ballan
Sometimes the outer ring on the balancer will slip on the rubber giving you a false reading. Just turn your engine over to tdc on #1 cylinder and see wear your mark is.
custom1106
Dec 19, 2010 12:50 AM
Monarchfootbal77
Feb 28, 2007 08:10 PM
Icicle
32
Oct 4, 2005 02:01 AM
switch900
Apr 22, 2003 07:38 PM
grayghost
Mar 27, 2003 07:54 PM
