Transmission won't shift into reverse
Old Jun 10, 2012 | 08:46 PM
81F150Custom's Avatar
81F150Custom
Unhappy Transmission won't shift into reverse
First time poster here --
I have an '81 F150 4.9L with the 3sp w/ OD transmission (SROD). Today I decided to check the fluid level for the gear oil in the tranny, assuming that it was probably low and probably hadn't been changed in years and years and years--this is the old farm truck, recently passed down to me.
After checking the level and topping it off with some 85W gear oil (planning on flushing and refilling it soon anyway), I started the truck, ran thru the gears, and it won't go into reverse! The actual shifter will easily go into the slot for reverse, but nothing. I can let out the clutch and it acts just like it's in neutral. I don't know what i possible could have done just pulling out the bolt, adding some fluid, and then tightening it back up.
Also, it easily goes into 1st and can drive around no problem -- just NO REVERSE!!
I tried searching the forums, if i'm reposting let me know and pleeeeaaaase direct me to the solution.
thanks
Old Jun 10, 2012 | 09:26 PM
ctubutis's Avatar
ctubutis
Welcome to the forum!
Ya know, I've read something similar to your problem not real long ago, guy took his truck to one of those 20-minute-oil-change places to have tranny oil added (or changed, or whatever) and something was screwed up on the transmission afterwards. I think it was the result of removing the wrong bolt in the side of the transmission, this one I think has a matching one on the other side and is part of the transmission assembly itself and not a fill/drain plug.
You can probably find it in the archives here in 80-86, I think it was within the past 4-5-6-or so months.
Hope this helps.
Old Jun 10, 2012 | 10:10 PM
ctubutis's Avatar
ctubutis
Well, I searched and couldn't find it, maybe it was part of a much longer thread.
With that being said, maybe one of the guys here who knows something about those things will stop by.
Old Jun 11, 2012 | 01:29 AM
81F150Custom
Ya know, I actually remember that exact thing happening to my dad while he still owned THIS truck!! Jiffy-lube type place that just did a basic service and it wouldn't go into reverse afterwards! Really jogged my memory there. I wish i knew how it was fixed...
I had thought exactly that (wrong bolt, wrong side) and smacked myself in the head after realizing it, but the bolt REALLY looks like what they showed in the Chilton manual. I looked on the other side after this happened and the passenger side bolt, while actually looking a lot more like it'd be for a filler :-/, is much smaller and just doesn't look like the diagram i saw. Shouldn't trust Chilton so much, I know...
If in fact this bolt was an important part of the tranny, since i'm sure you're on to something here... what could it be? How could i pull it out, then put it back exactly the same yet ruin something? It was a 13/16 bolt if that helps :-/ driver's side.
I wish I knew anything more about transmissions!! Gaaaahhhh
Old Jun 11, 2012 | 08:27 PM
82f100460's Avatar
82f100460
Yes....that was exactly what happened on the other thread...pulled the wrong bolt out!! And it was an SROD.
I will also try to find the thread.
Old Jun 11, 2012 | 08:33 PM
drumfield's Avatar
drumfield
Was this it?
https://www.ford-trucks.com/forums/3...d-reverse.html
Old Jun 11, 2012 | 08:48 PM
82f100460's Avatar
82f100460
Originally Posted by drumfield
Nope...not the one that we were thinking of...but the same problem We had one on here just a month ago or so.
Old Jun 11, 2012 | 08:51 PM
81F150Custom
Wow, well it sure sounds like it...! Same bolt, and I don't have reverse but I do have 1st gear.
Thanks Doug (that's my name, too!!)
Seems like it could be it, of course I hope it isn't because it would suck to take it to a trans shop to fix my two-minute blunder......
Old Jun 11, 2012 | 09:21 PM
jstitts's Avatar
jstitts
I have the srod too, didn't drive it for 7 seven years, forgot that you push down on the stick then left and up for reverse. Hope that helps.
Old Jun 12, 2012 | 05:36 AM
Ken Blythen's Avatar
Ken Blythen
I think this was the other thread - www.ford-trucks.com/forums/1160412-1983-f250-diesel-tranny.html
but it's a T19, not an SROD.
Old Jun 12, 2012 | 08:34 AM
82f100460's Avatar
82f100460
That's the one Ken!!!
Old Jun 30, 2012 | 02:23 AM
81F150Custom
Well, it's fixed -- i took it into the shop, since I have absolutely NO transmission work experience. But since I explained the problem (pin-thingy that holds the forks of the reverse gear fell down into the tranny) they had it fixed no problem. Those previous threads were great for reference! Still, 350 bucks....
Old Jun 30, 2012 | 04:12 PM
FilthyCatfish's Avatar
FilthyCatfish
I just went through a similar experience with my T19. I pulled the bolt that held on the reverse shifter arm. I had to pick up a new c clip, set the arm, and put the pin back in. Real pain in the ****; it turned a what should have been a 20 min gear oil change into a three day ordeal.
f3fidy
15
Jun 14, 2020 05:50 AM
Rbrumley08
May 24, 2016 10:06 PM
drew2fast
Aug 14, 2015 07:16 PM
akaero
Sep 26, 2010 05:22 PM
krane operator
1983 - 2012 Ranger & B-Series
Mar 31, 2007 11:34 AM
