fuel tank will it work?
Old Sep 23, 2002 | 10:46 AM
CrazyFordMan's Avatar
CrazyFordMan
The rear tank in my truck leaks when i get more than $10 in it i have a rear tank from a 83 pick-up and i was wondering if it would work?
1992 F250 5.8lEFI r/c l/b 4x4
Old Sep 23, 2002 | 01:33 PM
ddestruel's Avatar
ddestruel
No, your truck needs a tank with an intank eletric HP fuel pump anything from i think 88 or around there maybe 90 when they went from the frame rail pump to the in tank . Fell free to correct me if im wrong, but definately not a 1983 tank. i put a 1990 bronco tank and pump in my 96 ext cab short bed and it worked fine. youll just have to look around
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4039&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=474&.jpg
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
Old Sep 30, 2002 | 01:18 AM
stoab's Avatar
stoab
ive got an extra tank you can have out of an 89 f250 but youll have to pay shipping from seattle.you can email me @ bagoftricks@attbi.com
Old Sep 30, 2002 | 07:42 AM
Dermangin's Avatar
Dermangin
I have a similar problem the rear tank is leaking. I want to know how to drop the rear tank, and run just off of the front. My plan is to drop the rear, repair/or replace it and then re-install it.
What I don't know is if I can still run the truck if I drop the rear tank. It is my daily driver and I can't have it out of commission for more than an evening. If I can drop the tank and have a look at it I might be able to have it fixed. There is a shop in my town that repairs gas tanks, so I might give them a try.
Has anyone ever done this or does anyone know if it is possible?
Thanks in advance!:7
Old Oct 1, 2002 | 11:13 PM
924x2150's Avatar
924x2150
Old Oct 2, 2002 | 08:55 AM
Dermangin's Avatar
Dermangin
[updated:LAST EDITED ON 02-Oct-02 AT 09:56 AM (EST)]Can anyone help out on this issue? I want to know if it is possible to remove one tank, and keep the truck running on the other. My rear tank has a leak and I want to remove it, repair it and then reinstall. The problem is the truck is my daily driver and I need to keep it on the road.
Any help would be appreciated.
