High idle airconditioner
Old Jun 10, 2012 | 02:24 PM
pskelton's Avatar
pskelton
Question High idle airconditioner
I've been reading about the digital climate control unit and how it goes blank sometimes. Mine does this too, some. However my a/c will quite randomly too. I just shut it off and turn it back on and it comes back on. Additionally, it will go off with the high idle mod. Pressures are good and it works great otherwise. Any thoughts?
Old Jun 10, 2012 | 03:06 PM
MurderMode's Avatar
MurderMode
Sounds like an electrical problem. Maybe a short in your switch.
Old Jun 10, 2012 | 04:17 PM
zhilton's Avatar
zhilton
Check to the plug on the backside of the display to make sure it's all the way in. That would explain the display going blank from time to time. You could also check your heat sink resistor for the HVAC fan. You can get to it from the engine compartment side of the blower motor housing. Sounds like it may not be cooling completely and the automatic climate control is cutting out to protect it's self. Does the fan work at all fan speeds? Or only at the full/high speed setting?
Old Jun 10, 2012 | 04:21 PM
pskelton's Avatar
pskelton
thanks for the replies. The fan is never an issue. Its the compressor that is stopping. The air goes musty with no real indicator as to whats going on.
Old Jun 10, 2012 | 08:25 PM
zhilton's Avatar
zhilton
I realize that, but you might check it anyway. Some makes/models if the blower motor resistor isn't working right it cut the a/c compressor out....like the old 351 used to do when you went to WOT.
JoeLariat09
2009 - 2014 F150
Aug 5, 2014 06:49 AM
ExpySport
17
Aug 11, 2011 12:17 PM
4x4EX6.0
Dec 24, 2010 05:21 PM
Jays_Truck
Nov 20, 2009 10:23 AM
docdonnyb
Mar 10, 2006 06:45 PM
