Aerostar Ford Aerostar
2000 windstar
Old Jun 10, 2012 | 12:11 PM
glenster's Avatar
glenster
2000 windstar
since there is no windstar fourm maybe someone can help here, I have a 2000 windstar as second vehicle, battery keeps going dead, have replaced battery, alt and still have problem I dont see any lights on ao not exactly sure where to look next if I put an amp probe between neg cable and batt. post I show a 1.2 amp draw, disconnected the alt and still show draw.
Old Jun 10, 2012 | 12:52 PM
xlt4wd90's Avatar
xlt4wd90
Try measuring current between the positive battery terminal and the wires that fan out from there. At least those are distinct paths that you can follow, vs the negative side which is connected through all ground paths.
Old Jun 10, 2012 | 03:04 PM
aerocolorado's Avatar
aerocolorado
You can also try removing fuses, one at a time to isolate which circuit is drawing down the battery.
Keyless entry system? This might help: http://www.justanswer.com/ford/4x6ro...-question.html
Old Jun 10, 2012 | 06:46 PM
Jose A.'s Avatar
Jose A.
check in the darK to see if any lights remain ON, including any light under the hood which you can't see if the hood is closed and the same with the glove box light if any. Check that the radio is really OFF. Check if any power cable is connected to any power outlet, like the cigarrette lighter. Check inside the center console.
Old Jun 16, 2012 | 12:08 AM
96star's Avatar
96star
Get rid of windstar it will give you nothing but trouble. Expensive trouble -transmissionwise.
Fbg
Feb 8, 2025 03:42 PM
TucsonTripleB
20
Jul 24, 2017 06:41 PM
Forty9ford
Jun 24, 2010 01:35 PM
06gator
25
Jul 24, 2008 09:38 AM
87longbed150
May 14, 2007 07:23 PM
