Banjo Bolt Opinion
Old Jun 9, 2012 | 09:00 AM
AKPOWERSTROKE's Avatar
AKPOWERSTROKE
Banjo Bolt Opinion
I am toying with the idea of either removing the check valve or is it really worth buying upgraded bolts. Looking for Pros/Cons opinions whatever you got. I have an 03 Sep built 350 Thanks
Old Jun 9, 2012 | 06:28 PM
LKCKR's Avatar
LKCKR
I replaced my banjo bolts with ones from the 6.4L Powerstroke. They don't have the check valves and they have two extra holes in the shank for more fuel to the injectors. I got mine from KLM Performance just go to KLMStore.com 18.70 for two bolts. Real easy to install, the only thing, for the drivers side it' s easier to to take the cold side CAC tube off. Torque the bolts to 18 FT/LB. Hope that helps.
Old Jun 9, 2012 | 07:00 PM
VQT's Avatar
VQT
Correction 28 ft-lb not 18...
Old Jun 9, 2012 | 07:11 PM
LKCKR's Avatar
LKCKR
Correction 18Ft/Lb, these come with the updated Viton washers not the crush washers. I got the straight from a Ford Senior Master Technician.
Old Jun 9, 2012 | 07:13 PM
VQT's Avatar
VQT
Sorry if I am wrong. What's a Viton washer?
Old Jun 9, 2012 | 07:18 PM
LKCKR's Avatar
LKCKR
It's an O-ring, not sure what the whole make up of the washer is but it is black in color.
cutlass
18
Oct 29, 2021 07:21 AM
Gatordog
Oct 16, 2015 03:23 PM
Phillyc1
Feb 23, 2013 12:03 AM
Schmavic
Mar 13, 2004 07:30 PM
JJDDOOGG
Dec 12, 2002 04:21 AM
