Sponsored by: Real Truck
Fixing cigarette lighter & keyed wire
Old Jun 8, 2012 | 11:06 AM
carolinaskifftom's Avatar
carolinaskifftom
2 questions 1. I had a little air compressor plugged into the cigarette lighter hole. When I tried to pull the plug out, I pulled the lighter out of the hole in the dash. How do I get it back in? The two little tabs don't seem to be spring loaded and I can't just push it back in.
2. I am installing a relay for an air compressor and it should be connected to a wire that is controlled by the ignition switch. What is the easiest way to connect it to the ignition switch? Can I hook it to a wire coming off the fuse block, if so, what would the color code for the wire be?
The truck is a 2004 F250 Super Duty.
Thanks for the help. Tom
Old Jun 8, 2012 | 04:18 PM
SteveH-CO's Avatar
SteveH-CO
Check the owner's manual - they may show an accessory fuse spot you can use for your compressor. You will likely have to lightly disassemble the dash and study it to figure out how to re-engage the cigarette lighter, or replace the socket with one from Walmart (they carry a 3M brand metal socket that is pretty nice).
89gtstang
Aug 18, 2016 05:20 PM
Ridin'High
Nov 7, 2012 10:28 PM
ErrorS
Garage & Workshop
18
Mar 15, 2008 10:04 PM
Rufus0415
Aug 8, 2006 05:13 PM
