Compression
Old May 8, 2003 | 05:15 PM
Brian S's Avatar
Brian S
Compression
Glad to hear your motor has stayed together. Where were you six months ago when I made the same suggestion. I was told it was a bad idea, that the piston could be weakened by enlarging the pin bore and I would have a hard time finding a machine shop willing to try it.
Old May 9, 2003 | 03:27 AM
GT40man's Avatar
GT40man
Compression
i live close to a drag strip and circle track, i have access to 114 and 116 octane gas. i dont have cr problems.
Old May 9, 2003 | 08:11 AM
hellraiser's Avatar
hellraiser
Compression
How does polishing the chambers aid open chamber combustion?
doesn't that enlarge the chambers slightly also by a few cc's?
If that works, I would rather go that way. My 410 CI build is not that serious. Just want to stomp a few GM"s with it.
I can tolerate 9:5 comp or a little less. It'll still leave me some power adder options for later on. I still could get 400 hp out of it.The $300 for 4V cores could go on something else to help me complete the project.
"D"
Old May 9, 2003 | 05:12 PM
78bigbronco's Avatar
78bigbronco
Compression
It was my understanding that polishing the chambers smoothes out all the rough spots that can get hotter than the smooth surfaces as cause pinging. Polishing will reduce pinging and helps to promote an overall broader torque curve, although I cant say if it actually gains you a 'substantial' difference in power.
Old May 9, 2003 | 05:41 PM
hellraiser's Avatar
hellraiser
Compression
Thanks...I may go that route.
Old May 10, 2003 | 12:56 AM
macguyver's Avatar
macguyver
Compression
Also a polished surface won't allow carbon deposits which can glow and cause pre-ignition.
Old May 10, 2003 | 09:10 PM
78bigbronco
Compression
Exactly... thats what I meant by it reduces pinging - just didnt explain all the details
djmichael24951
Aug 17, 2013 03:39 PM
notch83
6.4L Power Stroke Diesel
Nov 9, 2012 01:02 AM
kellar
18
Nov 9, 2007 07:40 PM
metalmilitia
Jan 12, 2004 08:50 PM
HollywoodN2O
1978 - 1996 Big Bronco
Sep 14, 2002 12:24 PM
