Old May 6, 2003 | 02:22 PM
Ds7776's Avatar
Ds7776
Question 330,389
What family are the 330hd and md and 389 out of?? One of my neighbors had one in a dump truck when I was little but he couldnt tell me anything of it other than it was a darn good motor (330md) I want to try to find one to put in place of a 302 c4, dont tell me id be better off with something else because this truck is hardly used and i think it would be unique. Also will it bolt up to a FE ore 351 M trans??
Old May 6, 2003 | 02:33 PM
BB's Avatar
BB
330,389
They're from the FT family, a HD version of the FE engines. The bell will bolt up to the FE pattern but there's differences with the crank flange and pilot hole.
Barry
Old May 6, 2003 | 04:01 PM
rusty70f100's Avatar
rusty70f100
330,389
It'll be a good torquey low reving motor, virtually indestructable, and it will bolt to an FE bellhousing, as BBB said. I'd look for a C6 for it, and get a low stall torque converter, the stock one would probably work good. What's it going into?
Old May 6, 2003 | 06:37 PM
gtex's Avatar
gtex
330,389
I never heard of the 389. Is that an HD motor from the same series as the FT? I've heard of the 391, but not a 389.
Old May 6, 2003 | 07:16 PM
79Lariat's Avatar
79Lariat
330,389
The 389 was an MEL engine around 1958 if I remember right.
Old May 7, 2003 | 01:20 AM
BB's Avatar
BB
330,389
That was a 383.
Old May 7, 2003 | 02:11 PM
Ds7776's Avatar
Ds7776
330,389
The 389 i am refering to came in some 1970s dump trucks. The vehicle it might go in is a 1977 F150 2wd longbed farm truck. The 302 that it had is very worn out and i like Fes better so if it is the same then i like it
Also does anybody know about the BIG industrial motor from the 60s like the 401 477 and 534, I read about these in a Ford trucks since 1903 book! They sound like a cool motor that if some one were able to build into a performance motor would knock the snot out of anything!!
Old May 7, 2003 | 03:12 PM
79Lariat's Avatar
79Lariat
330,389
Oh, what the heck. 389---383, I knew it was some Pontiac or Chrysler thing!
Old May 7, 2003 | 06:28 PM
karljay's Avatar
karljay
330,389
I understand that the big 477/535 are really big motors, not just CID, but the actually size is bigger.
I read about these in a post a while back and it seems that there is nothing in the way of performance parts for these.
It would be an interesting project, but if I were looking for a really big motor I think I start out with a stroker kit for th 460 block.
Old May 7, 2003 | 08:32 PM
Ds7776's Avatar
Ds7776
330,389
I have nver heard of any reformance parts for the 401 477 or 534 ethier, and yes they are very huge blocks, so huge i doubt they would fit in a full size pick up but i would love to have one of these as well, i recently found one in somebodies shop that had been sitting for years but right now i dont have the funds or time for it, Plus even with there monsterous size one of these mills only had 266 horsepower that is a good amount but i think it could be better maybe simply milling the heads would help a good bit. As to the 389 ive never seen one of these but at one point i thought they were diesel because i read it was labeled XD but its not from what i understand. As to the 330hd it is as of today sitting in my shop and ready to go i pulled it out of a trashed ex schoolbus for $10 what a deal. The bus ran pretty well i even drove it around i even got the rear axle and clark 5 speed trans with but those are for future plans. I have a C6 for it but it may need to be flushed. Thanks everybody for the info!
Old May 12, 2003 | 10:51 AM
jrsroadhauze's Avatar
jrsroadhauze
330,389
The Clark 5 speed, if it is the overdrive 5th gear unit, is a real find. If your not going to use the tranny it will be worth some bucks.
Old May 12, 2003 | 01:52 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
My 1979 Motor's Truck Repair Manual lists the 389 from 1975 through 1978, ranging in torque from 175 to 180 at 3400-3600 RPM, and HP from 302@2700 to 318@2400.
All 4 barrell carbs. Note says "Heavy Duty" - not medium or light. Another picture clearly shows three compression pings on the pistons, just like the rest of the MD and HD motors.
ak
Old May 12, 2003 | 05:39 PM
gtex's Avatar
gtex
330,389
It must have more torque, numbers don't make sense for anything with 389 cubes and 300 HP????
Old May 13, 2003 | 09:31 AM
krewat's Avatar
krewat
Stupid me, I got them backwards! 300 ft/lbs of torque, only 180 HP.
ak
Old May 13, 2003 | 02:15 PM
Ds7776's Avatar
Ds7776
330,389
But is the 389 an Fe or FT or something else. Also just a notice someone said the FT have a small difference somewhere. What exactly is it and where can I find parts for it?
