Need mirror wiring help
Old Jun 6, 2012 | 03:14 PM
hammer65's Avatar
hammer65
I found a mirror for my 2003 and was going to install it. (drivers side Towing Mirror.)
Someone had replaced the mirror before, and cut the plugs off and soldered everything back together.
I can do the same, because it has worked fine, but I would like to put the plug back on the truck end. The new mirror has the correct flat plug.
I have pretty much figured it out, except they have 2 yellow wires on the truck side soldered to the yellow wire on the mirror.
I can't believe that is correct.
Is the other yellow wire for heat, and go to one of the black mirror wires?
So does anyone know about this or have a wiring diagram of the door plug.
Thanks to all. Jim
Old Jun 6, 2012 | 04:20 PM
Ponyboychris's Avatar
Ponyboychris
Take a look here: New Mirror installation
Old Jun 6, 2012 | 04:44 PM
landmobile's Avatar
landmobile
Yellow is common to both motors, violet goes to the up-down motor and green goes to the left-right motor. Reversing polarity changes the motor direction.
My guess is that ford used the driver's side plug as a junction point for the common motor wire. That would explain why there are 2 yellow wires on the door side of the connector.
Chris
Old Jun 6, 2012 | 07:10 PM
hammer65's Avatar
hammer65
Thanks Chris.
Old Jun 6, 2012 | 07:13 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
See S317 in this Print
File Type: pdf
Old Jun 6, 2012 | 07:38 PM
hammer65's Avatar
hammer65
Thanks Richard, I think I understand.
Douglas Paddington
Escape & Escape Hybrid
Jan 30, 2017 01:32 PM
sgtrdb
6.4L Power Stroke Diesel
Mar 24, 2013 02:55 PM
smith.pete
Jun 14, 2010 10:54 PM
