Isspro Gauges
Old Jun 6, 2012 | 01:58 PM
MiamiPSD's Avatar
MiamiPSD
Isspro Gauges
Ready to purchase gauges. Im torn between the EV2 and the performax line.
Any input will help.....
Old Jun 6, 2012 | 02:14 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
I just installed performax, (8) total. They are really nice. They daisey chain together on the same three wires. You can just unplug them and move them around if your not sure of where you want them. The lighting is great, way better than the stock lighting, I think the EV-2 are the same. I don't have any experience with those. The advantage is you can run up to 17 on those three wires so you don't have a big bundle to deal with under the dash. Other guys will jump in with info so just wait a little while. Both are nice and have cool features. Customer service is real good. You can buy them from Riff Raff Diesel, great customer service there to.
Old Jun 6, 2012 | 02:16 PM
woodnthings's Avatar
woodnthings
Both are great. If you want multiple gauges the Performax is nice since you mount the ESP (brain box) under the hood and the few signal wires all go to the gauges via daisy chain. With the EV2's you run a wire bundle from each sender to each gauge. Not a big deal for 90% on those installing gauges. If you feel you will go gauge crazy, you may consider the Perfomax series.
Riffraff has great prices on both.
Riffraff Diesel Performance Parts: - Isspro
Old Jun 6, 2012 | 02:17 PM
stinson 108-1
stinson 108-1
Just noticed your sig says you have isspro gauges?
Old Jun 6, 2012 | 02:28 PM
MiamiPSD's Avatar
MiamiPSD
Yeah......I DID have Isspro gauges till last week when someone decided they wanted them.....break in time.. Anyway, I have a choice of the two and yes I will be buying them from Clay.
Old Jun 6, 2012 | 02:42 PM
stinson 108-1
stinson 108-1
Sorry for your bad luck, was just wondering. Maybe since you have the senders already there, they are still there right? You should use the same product line, unless you want to expand on what you had.
Old Jun 6, 2012 | 03:41 PM
CSIPSD's Avatar
CSIPSD
Performax offers peak recall, data logging, ease of install, easy to move and change... They will have the programable warning lights, there in now, just still testing the software so the end user can adjust them...
EV-2 offer the warning lights and the programing software is complete for them now. They are not quite as easy to install, as all the wires have to go to the gauge, but there no harder and really slightly easier then most standard gauges.
There is 0 differance in the look, or lighting.
Old Jun 6, 2012 | 03:56 PM
MiamiPSD's Avatar
MiamiPSD
Thanks guys
Old Jun 6, 2012 | 09:13 PM
bigb56's Avatar
bigb56
Is this only for the new EV-2 gauges, or can my approx 2 year old ones be programmed?
Old Jun 6, 2012 | 11:20 PM
CSIPSD's Avatar
CSIPSD
If there 2 years old I doubt they have the LED in them. I know they do not have the newer faces in them.
Contact Isspro, I bet they will update them for a nominal fee.
Old Jun 7, 2012 | 03:50 AM
MiamiPSD's Avatar
MiamiPSD
Joe, does the ev2 have a different pointer than the performax? Don't know where I read that.....
Old Jun 7, 2012 | 08:16 AM
CSIPSD's Avatar
CSIPSD
Nope... Same pointer, same faces.
Old Jun 7, 2012 | 01:21 PM
MiamiPSD's Avatar
MiamiPSD
Thanks guys for your input. Will be ordering the Performax series. That way I can get a few other gauges in the future.
Old Jun 7, 2012 | 11:17 PM
mikeb2's Avatar
mikeb2
I just installed autometer
I just installed autometer ultra light and they are nice. Very solid and good sending units and hardware. Mike B
Old Jun 8, 2012 | 09:50 PM
Josh88Ford's Avatar
Josh88Ford
I run performax gauges. If I was to do it again, I would run a mechanical boost gauge. The electronic sensor isnt quick enough to pick up surge and is delayed.
