whats that tick?
Old Jun 5, 2012 | 08:12 PM
WorkhorseF250's Avatar
WorkhorseF250
whats that tick?
the truck in my sig has a tick its quite loud when held at 1000rpms anyone know what is causing it just by the sound?
http://s968.photobucket.com/albums/ae161/workhorse250/?action=view¤t=IMG_0295.mp4
Old Jun 6, 2012 | 11:22 AM
berry1234's Avatar
berry1234
Doesn't sound bad to me. Maybe VCT noise that is normal.
21574 4.6L 3V/ 5.4L 3V ENGINE TICK/RATTLE FROM VCT 800-1200 RPM - DO NOT ATTEMPT SERVICE
2009-2010 F-150 WITH 4.6L 3V, 2005-2010 F150 WITH 5.4L 3V,2005-2010 MUSTANG WITH 4,6L 3V, 2005-2010 F250, F350 WITH 5.4L3V, 2006-2010 EXPLORER/MOUNTAINEER WITH 4.6L 3V ENGINE, 2007-2010 SPORT TRAC WITH 4.6L 3V ENGINE, AND 2005-2011 EXPEDITIONS AND NAVIGATORS WITH 5.4L 3V ENGINES. SOME CUSTOMERS MAY BE CONCERNED WITH TICK/RATTLE NOISES FROM THE VARIABLE CAM TIMING (VCT) ON LIGHT TIP-IN ACCEL BETWEEN 800-1200 RPM. THIS CONDITION MAY BE MOST NOTICEABLE OPERATING VEHICLE IN CONFINED AREAS SUCH AS A DRIVE-THRU. THE NOISE IS ELIMINATED WHEN VCT SOLENOIDS ARE UNPLUGGED. THIS CONDITION SHOULD BE CONSIDERED A NORMAL CHARACTERISTIC OF THE ENGINE. DO NOT ATTEMPT ENGINE REPAIRS TO CHANGE THIS NORMAL CONDITION. THIS CONDITION DOES NOT AFFECT PERFORMANCE OR DURABILITY OF THE ENGINE.
Old Jun 7, 2012 | 09:28 AM
SuperDutyScaler's Avatar
SuperDutyScaler
not to sound like a d$ck but good luck with that. My 2004 F350 has a tick for three months now, first i thought it was a bad exhaust gasket so i bought new header gaskets and all new studs and replaced them first. But my tick still didnt go away, so then i installed all new plugs, checked the COP's and checked the injectors and guess what i still have the tick! Mine also does it at about 1000RPM and stops around 2500RPM, id rather have broken exhaust studs and spend the money to have them drilled out and replaced and have the tick go away rather then not having problems but still have this dam tick. Its getting annoying when im see someone next to me and i hit the gas and they look they look like what the hell is that noise....?
Old Jun 7, 2012 | 10:07 PM
aerocolorado's Avatar
aerocolorado
My 5.4 developed a ticking sound that I was sure was either a sticking lifter or possibly cracked manifold. Turns out it was a precursor of the dreaded blown spark plug. It finally blew last week. After repair, no ticking sounds.
Old Jun 7, 2012 | 10:11 PM
WorkhorseF250
Ive changed plugs passanger side manifold and gasket, it was still ticking, but i have found just of late that putting the truck to stock settings with the cortex superchip it doesnt tick if at all anymore.... kinda confused
Old Jun 8, 2012 | 04:01 PM
SuperDutyScaler
ive been trying for three months to fix the same type of tick. Ive so far added new exhaust studs on both sides, new header gaskets on both sides, new y-pipe to cat exhaust gasket, 8 new spark plugs. For some odd reason mine is quiet in Park or Neutral but ticks when in reverse or Drive, so now i think it loose TQ bolts? I would say check the exhaust but you replaced that already, your truck does have cam phasers and they go bad all the time on the newer three valve motors. it goes away because the superchip changes the timing and makes the phasers change the degree, if they are bad thats whats causing your ticking
fordman19762003
Modular V8 (4.6L, 5.4L)
Dec 6, 2012 10:50 AM
Fox Fader
1997 - 2003 F150
Feb 2, 2011 08:58 PM
bmcdowall
Oregon Chapter
Dec 15, 2010 04:38 PM
gcozmo
2004 - 2008 F150
35
Jan 9, 2010 12:36 AM
shane7209
1997 - 2003 F150
Dec 24, 2006 06:02 PM
