header recomendation
Old May 6, 2003 | 11:46 AM
chissler's Avatar
chissler
I would like to know what headers you guys like or dislike. I'm going to put some on a 390 in a '66 F-250 2wd.
Old May 6, 2003 | 11:52 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
L&L Makes great headers. If thats too pricy for ya, maybe Headmans will work. I have never liked Hooker, they seem to fall apart fast.
xericx's Avatar
xericx
I have a set of flowtech headers on my '72. They are made by Holley. Paid about $120ish for them and was supprised by the quailty. Definatley worth the mony.
Old May 6, 2003 | 12:42 PM
1 TON's Avatar
1 TON
Love my Heddman's, great price"you can pick up a pair for under 200$" Well built, and a good fit. What more can you ask for?
Old May 6, 2003 | 01:26 PM
gtex's Avatar
gtex
Not impressed with my Dynomax. Bad fitment problems with 69 F250, 390, C6 and Bendix steering box. I also have a hard time sealing them at the heads.
The guys here seem to have some success with some of the cheaper brands, but I'll be spending the $$ to get a good set the next time I go shopping for headers.
Old May 6, 2003 | 08:20 PM
mwc4275's Avatar
mwc4275
I don't like my Headmans. The flanges were too small and leaked, so I had to build them up and grind them flat. They are also really thin and bend when you tighten them down the first time. So if you ever take them off you have to beat the flange back out straight again. It's a real pain. I would definately spend the extra money on a quality header with a thick flange that won't bend.
Old May 6, 2003 | 08:53 PM
highboy_73's Avatar
highboy_73
I have flowtechs on my truck right now and i hate them with a passion i have never got the to seal up in 2 years. and where the slip together i had to weldthem up to stop leaks. I have not seen L&L headers for FE engines but i just bought a set of headman new off ebay for 46 dollars. i would recommend them.
Old May 7, 2003 | 01:24 AM
Ratsmoker's Avatar
Ratsmoker
I love my flowtechs. They don't have a slip joint. You must have a different model. Mine fit good and have never leaked. Use the paper gaskets they give you with the headers. These things are great!
Old May 7, 2003 | 06:12 PM
Tmod700's Avatar
Tmod700
I have Doug Thorley's on mine and have never had a problem or had to change a gasket. Been running them for about 5 years.
One drawback is if you are trying to save weight, They are heavy. 14 Gauge tubes and 3/8" head plates. Don't leak though!
Old May 7, 2003 | 09:34 PM
rusty70f100's Avatar
rusty70f100
I have hedman's on mine, and couldnt be happier with 'em. Just make sure you get the bolts good and tight the first time, and I would recommend aluminum collector gaskets to prevent blowout. Have fun!
Old May 7, 2003 | 10:38 PM
Andysutt's Avatar
Andysutt
I ordered a set of DynoMax headers for my 66 390 C6 and I'll let you know how they are... I paid 108.99 for them outta jegs... Well worth the money I think. And they said they'd work w/ power steering.
Old May 8, 2003 | 07:18 AM
William's Avatar
William
My advice, "DON'T"....
Old May 8, 2003 | 12:03 PM
Rat wagon's Avatar
Rat wagon
I agree with William here, I must say Ive never had hedders first too though, but I'll let her rip. I was looking into hedders and found that I could pay upto 700 dollars for a 6-9hp gain, thats the manufactures claim on a 454 cheb plus I'll loose some lowend.
Old May 8, 2003 | 12:15 PM
Andysutt's Avatar
Andysutt
It depends on the motor also...
on a 390 the manifolds suck... In my opinion.
If your satisfied with what you got now, I wouldnt buy headers until your manifolds are shot (rusted thru or whatever)
Then I would buy headers (even small ones) as they are usually cheaper than stock manifolds.
I dont have headers on my chebby, but Im putting them on my ford... as I hated the stock manifols on the 390
Old May 8, 2003 | 07:49 PM
CACWBY's Avatar
CACWBY
You should do a search on this topic and even my user name- I may have the record, I just recently went through Three sets to get an acceptable set - but even then I'm still fighting them a little. I have 390 with E-Brok Heads in 67 2wd.
I have a set of Dyno Max that we beat up (so I can't return) to make clear the steering gear and then would never seal due to bad port match, tried and returned Sandersons(another bad port match), finally went with Ford Powertrain Applications (FPA) great port match, passenger side was very close to frame(but allows for starter replacement w/o removing header), and still working on keeping bolts tightened. But in spite of this, Headers are part of mix if going for something besides stock. You really should research and make sure of Port Match before using and the Cerama Coat is worth far more in starter savings and reduced engine room temp. Bottom Line: It's your truck, ( your baby ) so don't short change it.
