Sponsored by: Real Truck
Mileage?
Old Jun 8, 2012 | 10:42 AM
  #61
maverick22's Avatar
maverick22
I found these...CNG Conversion Kits, CNG Tanks, CNG Cylinders One large enough to be of any use on a big heavy truck is going to cost you and is precisely why it's not a cheap conversion. Can probably find one used, but keep in mind they have an expiration date (15-20yrs) and they can't be legally used after that.
Good luck, keep us posted!
Old Jun 8, 2012 | 11:20 AM
  #62
DairyFarmer5's Avatar
DairyFarmer5
Thanks Maverick, you've been a HUGE help!
Old Jun 10, 2012 | 11:49 AM
  #63
DairyFarmer5
Okay, so I did some more work, and I found that it's going to take me about 3 years for the CNG to make up for itself.... Not bad....!
Old Jun 10, 2012 | 12:21 PM
  #64
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
edit: I'm just going to play nice
good luck getting better MPG's
Old Jun 10, 2012 | 12:25 PM
  #65
Skill_Kills's Avatar
Skill_Kills
Any time ive seen stuff like this (conversions) you either need to keep the vehicle FOREVER to make it worth it in the long run. besides now you'll have 2 different fuels to fill up on.
Have you come across what kind of mileage to expect with CNG? I know we used to have a truck that ran on LP around the farm and mileage was crap but with the amount of LP we used at the farm and the price we could get it at made it bearable.
all 6 of the trucks on my farm get less than 10 mpg. just the nature of the beast with short trips and hauling stuff
Old Jun 10, 2012 | 02:18 PM
  #66
Knothole's Avatar
Knothole
Most honest folks get poor mileage. Dishonest.....well.....
Old Jun 11, 2012 | 01:34 PM
  #67
dirtcrazy's Avatar
dirtcrazy
I feel you are looking at this from the wrong angle. What sort of exhaust changes have you made? Long tube headers improve the low to mid RPM torque - hard to find though. What final drive ratios does it have? Too tall of a final drive will decrease your available low speed torque, although a shorter ratio may cut into your freeway mileage. 4WD? The extra weight will affect your mileage, but being on a farm, 4WD may be required. How many miles are spent on the highway vs around the farm? Stop and go is a destroyer of mileage in any vehicle.
I feel converting to CNG will not make any difference in how much fuel you use. Mainly because the engine was not built to run CNG. It can, but it's performance and mileage will suffer since the compression ratio and cam profile are setup for gasoline.
I'm curious how a dual fuel system would work on modern day EFI vehicles: two sets of injectors: one for gasoline and the other for CNG. Swap the two narrowband O2 sensors with widebands to allow the different air fuel ratios (CNG runs much leaner than gasoline). Either a piggyback ECU to control the CNG or a completely new ECU that has two tunes - one for gas and the other for CNG. Not to mention the dyno time to get it tuned properly. I dunno, that sounds quite expensive.
Just as many has said before, these trucks are haulers, not fuel sippers. Your mileage problem is most likely the weight you're hauling. They tune them to lean out when running light and to richen up when there's a load. If you try to run lean when loaded, pistons like to melt. It's the nature of the beast. My F350's mileage drops below 10MPG just hauling my sister's three horses around. What do you think it would do with 10,000 lbs behind it?
_____________________________________
02 F350 XL V10 6sp Manual 4WD 4.30 gears
Old Jun 11, 2012 | 01:38 PM
  #68
DairyFarmer5
You guys are mistaken. I don't care anymore about better gas mileage, I now care about better GAS price, that's why I'm turning to CNG, because it runs about $1 a gallon, and my dad wants to install a CNG tank on the farm, so I won't have to pay for the system, I will just have to pay for the system on my truck!
Old Jun 11, 2012 | 02:50 PM
  #69
dirtcrazy's Avatar
dirtcrazy
Oh, I see. This should be interesting.
Old Jun 11, 2012 | 03:25 PM
  #70
2000silverbullet's Avatar
2000silverbullet
Originally Posted by DairyFarmer5
Okay, I am interested in a 1999 Ford F-250 4x4 5.4L XL, and I was wondering, if I purchased a Superchips Flashpaq 1865, how much would that increase on the gas mileage?
Thanks
You guys aren't answering my question, how much would it increase my gas mileage of I add the chip?
Thanks A/Ox4.... Is there anyway to increase my gas mileage?
I just need some way to increase my mileage by 10 or 5, it doesn't matter, I just need more mileage! Is there any really effective way???
Well, can someone give me a complete list of little and big tips for better gas mileage?
How are we supposed to know what your concerns are at this point? You're kind of all over the place...
The setup costs have to come from somewhere/someone, whether it's you or your dad, so that has to be taken into consideration if it's going to be a true comparison of whether there's benefit to going this route. If someone else is picking up part of the tab of a fuel conversion, then that's great, there's your fuel savings. More beer for the fridge!
Old Jun 12, 2012 | 06:52 AM
  #71
DairyFarmer5
I don't drink
Old Jun 12, 2012 | 09:44 AM
  #72
dirtcrazy's Avatar
dirtcrazy
That's great, neither do I. But does that mean you can't mentally replace beer with your favorite beverage? For me, it's Mountain Dew. ;-)
Of course, too much Dew will get me in trouble....."Uh sir, would you mind explaining that left turn back there?"
Old Jun 12, 2012 | 12:56 PM
  #73
redford's Avatar
redford
FTE Leadership Emeritus
The price isn't the entire issue. Sure, maybe you pay a buck for a gallon of CNG, but how far will that take you? What you need to look at is what kind of fuel mileage will you get with a truck converted to CNG. You can't do a 1 to 1 comparison with gasoline, it isn't that simple. It takes 21.7L of CNG at 2400 PSI to equal the energy of one gallon of gasoline.
Also, the gasoline engine is optimized to burn gasoline. It is not optimized to burn CNG. CNG has a much higher octane number. Very high static compression ratios and different spark advance maps are needed to utilize this higher octane efficiently.
Old Jun 12, 2012 | 02:06 PM
  #74
dirtcrazy's Avatar
dirtcrazy
That's what I was thinking too. Those "inexpensive" conversions do nothing to the spark maps or the compression ratios. So practically, mileage and performance will suffer and null the cheaper cost of the fuel. Hmmm......
dybeepvw
Sep 1, 2007 09:41 PM
Toreador_Diesel
Feb 27, 2006 07:27 PM
countryF150
1997 - 2003 F150
22
Nov 7, 2005 11:19 AM
SDTruckMan
Modular V8 (4.6L, 5.4L)
25
Aug 3, 2005 06:04 PM
macmanns
Feb 6, 2005 10:11 PM
