So what would cause low compression, white smoke and excessive carbon build up... All relates to #8 cylinder. Original symptom was severe white smoke. Unplug #8 injector smoke goes away. The ford dealership said it low compression but not abnormally low. I don't have the numbers.
Did you every do a leak down test to find out if it was the valves or rings causing the low compression
No I didn't... I tried and the glowplug broke, just now got time to pull the head. It has a ton of carbon all over the valves and piston... The glowplug hole is completely carbon filled.
If that cylinder wasn't firing properly, carbon buildup is going to be there. I'd pull the valves and clean them all up first. Then I'd turn the motor over by hand to get the piston to the top of the cylinder and clean it as good as you can being very careful not to damage the cylinder.
If you had low compression on that cylinder, I'd take the head to a machine shop and have them check the valves on that head close. They should be able to tell if you have a valve problem. Rotate the motor so the piston is all the way down in the cylinder too, see how the cylinder looks, as much of it as you can anyway.
If the head/valves check out, and you had low compression, the only thing left is broken rings, bad cylinder wear..
By the way, how did you do a compression check, with a broken glow plug in the head??
