head removal...
Old Jun 5, 2012 | 05:21 PM
KonaGrown's Avatar
KonaGrown
Originally Posted by KonaGrown
I would stuff rags in your injector holes also, if you turn it over. Who knows where that glowplug tip will end up.
Thinking about it... I think maybe throw your injectors back in so you can get pressure on that glowplug tip. Otherwise you wouldn't make pressure.
Old Jun 5, 2012 | 06:13 PM
427 fordman's Avatar
427 fordman
Don't close the hood, REMOVE it if you crank it over. You don't really want a dent from the inside of the hood poking up from a glow plug. And make sure nothing else is in the way in case it comes out.
I'd for sure try this before pulling the motor.
Old Jun 5, 2012 | 06:48 PM
85F250Diesel's Avatar
85F250Diesel
A blanket folded up real thick over the GP area is a good idea as well, those things can come out moving real fast sometimes.
Old Jun 5, 2012 | 06:53 PM
matowns21's Avatar
matowns21
I don't plan on pulling the motor just the heads..
Old Jun 5, 2012 | 07:11 PM
matowns21's Avatar
matowns21
Old Jun 5, 2012 | 08:25 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
Good luck man. Let us know how you get it out. I hate other's pain but learn a lot from it.
Old Jun 5, 2012 | 08:44 PM
matowns21's Avatar
matowns21
I need all the luck I can get... Thanks I think this one is gonna be a doozey...
Old Jun 6, 2012 | 06:04 AM
DIYMechanic's Avatar
DIYMechanic
You will want to put the injector back in that cylinder (the idea is to use the compression do push the GP out, and without the injector in that cylinder there will be no compression), but whether you put it back in the others is up to you. If you leave them out you will pump some fuel and oil into the cylinders, but it won't hurt anything as long as you blow it out of the cylinders be cranking it with the glow plugs out of the heads before you button everything up when you're done. I would just lay the VC back over that bank, and if you can get a vice grip on the GP I would do that too so it doesn't end up inside the engine someplace. It could get sucked into the cylinder, but I would be more worried about it falling down one of the ports in the head after it is blown free of the hole.
Old Jun 6, 2012 | 05:28 PM
jiveturkey692000's Avatar
jiveturkey692000
I had a broken one today on the passenger side. I can't get the tip out. Even with the truck running
Old Jun 6, 2012 | 08:34 PM
matowns21's Avatar
matowns21
Sounds like you are in the same boat as me...
Old Jun 7, 2012 | 12:25 AM
jiveturkey692000
Yeah seem to be. Got to drive to work so hopefully it will be ok. I put the hollow glow plug body back in for now. Hopefully it will stay put. I read quite a few threads about people just driving them. I don't know. I will probably end up pulling the head but I really don't have time right now. I'm working 80 hours a week.
Old Jun 7, 2012 | 04:14 AM
jiveturkey692000
Double post
Old Jun 27, 2012 | 03:47 PM
  #28
matowns21's Avatar
matowns21
Alright I have the head off, wooo that was a challenge... The cylinder looks ok, but there is a ton of carbon build up on the piston and valves... The other three look like new but #8 looks terrible. Any ideas...
Old Jun 27, 2012 | 04:33 PM
  #29
Talyn's Avatar
Talyn
The only suggestion I have is to remove the injector cup to get it out with the cylinder at topdeadcenter.
At that point, i'd just replace all 8 injector cups though.
You need a removal tool and install tool though
Old Jun 27, 2012 | 04:34 PM
  #30
Talyn's Avatar
Talyn
Ooops, you already got it out.
8 is a weak cylinder on our trucks.
