head gasket question
Old Jun 5, 2012 | 10:44 AM
joekacker's Avatar
joekacker
So my 91 f150 has been lacking power for a long time. I was lazy and did not look at the cause. Well now I have found a very small amount of wendys frosty in my oil. Not sure how long the head gasket has been leaking. But will it hurt my engine to drive it with water in the oil? I'm fixing this weekend.
Old Jun 5, 2012 | 11:43 AM
big vann's Avatar
big vann
When a head gasket lets go all the crap(rust flakes,grit,dirt) from the cooling system mixes with the oil and scores the bearings and covers the inside of the engine.Yes it looks like a Wendys frosty,but drain the pan to verify.Even if you change the oil it'll still get contaminated again very quickly.Hate to say it but the damage is done before you realize the gasket's done.If you keep driving it,it will get worse.Now you could replace the head gaskets and then clean out the engine by running seafoam and a couple of oil/filter changes while you hunt for a replacement engine.The life/reliability of the old engine is greatly reduced although it probably will still run(if you also change the plugs)
pi653
Nov 26, 2016 10:10 PM
neevnav
Nov 11, 2007 01:57 PM
cookch1
Aug 27, 2004 12:19 PM
murder4hire
1983 - 2012 Ranger & B-Series
19
Oct 18, 2003 01:32 PM
