Changing Head Gasket
Old Oct 14, 2003 | 02:02 AM
murder4hire's Avatar
murder4hire
We've had a '92 Ranger XLT 4.0 for 4 years and it has just been sitting the whole time because the head gasket is supposedly blown. I decided to fix it a couple weeks ago and I am almost ready to take off the heads and change the gasket. I just drained the oil after I was well into tearing the engine apart, and noticed that it was black. There was no brown, nothing white on top or anything, which is what I was told would be in the oil if the head gasket had really blown. Is it possible that its just all seperated because it has been sitting so long, or do you think its not the head gasket at all. I also noticed that the spark plaugs had HUGE gaps, could this have been because of the blown gasket, or could it maybe be misdiagnosed as a blown gasket, I dont know how it could be, but who knows. Thanks for any help.
Old Oct 14, 2003 | 04:54 AM
ctfuzzy's Avatar
ctfuzzy
A blown head gasket/ warped/cracked head can cause a large variety of symptoms;
water in the oil
oil in the water
combustion residue (exhaust) in the cooling system
. . or none of the above.
If you have established that there is no water in the oil or vise versa, I would recommend a compression test as a next step propr to pulling the head. Heck, you might even want to pressure test the cooling system before you pull that head too.
HTH.
Old Oct 14, 2003 | 09:39 AM
wolfen's Avatar
wolfen
Hi murder4hire,
your symtoms don't describle a blown headgasket and that's what ctfuzzy is leading up to, correct ctfuzzy ?
Old Oct 14, 2003 | 10:42 AM
amp17757's Avatar
amp17757
If the previous owner didn't give you any details or information, it's kinda hard to know exactly what's going on. If indeed a head gasket is blown between 2 cylinders, but STILL SEALING all the coolant & oil ports, then there would indeed be no exchange of oil, coolant, & exhaust debris. But, the compression check that ctfuzzy mentioned WOULD REVEAL IT (very low compression in 2 neighboring cylinders). If NONE of the cylinders reveal a compression reading significantly lower than all the rest, then CHECK OUT ALL THE CHEAP EASY STUFF FIRST, before considering pulling heads.
Old Oct 14, 2003 | 05:22 PM
murder4hire
Well, I'm already about to take off the heads, so I'm just gonna change it. I've already spent hours and hours taking everything apart, its getting a new head gasket whether it needs one or not.
Old Oct 15, 2003 | 06:27 AM
ctfuzzy's Avatar
ctfuzzy
Here is to hoping!
Here is to hoping you don't have the same symptoms when you're done!
Good luck, and *please* let us know what you find.
Mike.
P.S. Do yourself a favor - while the head is off take it to a machine shop and have it magnafluxed. It's cheap and it may very well show you a surprise you didn't expect (but were happy to find before you remounted the head).
Old Oct 15, 2003 | 06:35 AM
ctfuzzy's Avatar
ctfuzzy
Originally posted by wolfen
Hi murder4hire,
Actually, I am just thinking "a pain to take apart - only do it once."
Given the lack of water/oil contamination I think the chances are just as good the head is cracked as that the gasket is blown. In *a lot of cases* a crack can escape casual inspection thus magnafluxing is mandatory. Fortunately it is still a relatively cheap process to have done (you can even do it yourself if you want).
Naturally, this is just one lazy guys opinion.
Old Oct 15, 2003 | 09:38 PM
murder4hire
How exactly does magnafluxing work?
Old Oct 16, 2003 | 06:13 AM
amp17757's Avatar
amp17757
Murder4hire, put quite simply, the head is dusted with iron dust, then subject to a strong magnetic field. The magnetic flux lines will be concentrated at any spot where the metal is compromised, and so will the iron dust, revealing visually the compromise.
Old Oct 16, 2003 | 05:24 PM
murder4hire
Thanks. I read about it last night, seems simple enough to me.
Old Oct 16, 2003 | 05:42 PM
wolfen's Avatar
wolfen
Hi ctfuzzy,
A blown head gasket/ warped/cracked head can cause a large variety of symptoms;water in the oil
oil in the water
I was actually agreein' with you all along ! Your diagnosis sounds correct!
Old Oct 16, 2003 | 06:09 PM
murder4hire
I heard that since the truck has been sitting for 4 years that the water and oil would have sepoerated and then evaporated or something like that. Is this possible?
Old Oct 16, 2003 | 07:26 PM
Ken00's Avatar
Ken00
Water and oil are not miscible so they would seperate and I believe the density of water is less than oil so it would come to the top. Now I'm not sure how much evaporation would occur in a pretty much sealed crankcase.
Old Oct 16, 2003 | 10:10 PM
murder4hire
I thought the same thing, but they said that it would like bubble up or something and coat the sides.
Old Oct 17, 2003 | 01:22 AM
Leo_T's Avatar
Leo_T
I would think the gas would go bad after that long sitting.
