what power window kits you guys using? (53-56) - Ford Truck Enthusiasts Forums
Old 10-02-2005, 11:37 AM
mark914
mark914 is offline
mark914 is gaining momentum as a positive member of FTE.
seems like a LONG time since i posted on here. but my truck project is rolling forward once again. (ill get some pics up soon!)
I got 1 piece side windows for my 56 F100, and was going to make them power. What kits are any of you guys using? what kits have you heard good (or bad) things about? I was thinking of Specialty Power Windows, their kits seem to be a bit more ($405) but have a decnt reputation, its a cable driven kit using GM motors.
Thanks!
Mark
Old 10-02-2005, 10:22 PM
herman.r
herman.r is offline
herman.r is starting off with a positive reputation.
Hyundi power window motors are cable driven and are very easy to install.Mine are from a mid eighties car.I used the rear because they go straight up and down and usually have less wear than the front.20 bucks at the local pick a part for both and about 30 min to remove.Then I used the crome switches from a mid eighties GM car.The wire harness and RH single switch from the pick a part for 2 bucks.Again from the rear of a fordor.The double switch I bought new at Napa for 25 bucks and the harness from a mid eighties 2dr GM car.
Just my two cents worth.Don't know if you have unlimted budget.
Old 10-02-2005, 11:44 PM
rhw's Avatar
rhw
rhw is offline
rhw is gaining momentum as a positive member of FTE.
Now your're talkin!! That'sa what I love to hear! Cheap remedies! Bo-yaah baybee! sorry... saving money has that afect on me....
Old 10-03-2005, 12:14 AM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
I like the Bosch powered flex drive kit from Auto-Loc although I used units from the rear doors of a Cadillac
Old 10-03-2005, 12:13 PM
LEckart's Avatar
LEckart
LEckart is offline
LEckart is starting off with a positive reputation.
I bought some Autoloc units off Ebay but next time I think I will look at the salvage yard to see what is available. The Autolocs work fine I just want to see what else might be available at less cost.
Old 10-03-2005, 12:58 PM
AXracer's Avatar
AXracer
AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I bought a set of no name cable drive units from one of the ebay stores that sell hotrod parts. Units are fine and easy to install, just didn't include any instructions.
Old 10-03-2005, 01:45 PM
tacson's Avatar
tacson
tacson is offline
tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.
AX do they work good? Are you talking about the ones that go for about $99 or are you talking about the ones that look like the EZ-wire/ Its A Snap Power window kit?
Old 10-03-2005, 02:10 PM
AXracer's Avatar
AXracer
AXracer is offline
They work smooth and are easy to install. They resemble a T square with a curved tail and the motor hanging off the tail. They look identical to the "Dolphin" kit EZ wire sells for 145.00, and replaces the entire OEM window regulator mechanism. I think I paid 125.00 for mine.
Old 10-03-2005, 07:20 PM
CIAF's Avatar
CIAF
CIAF is offline
CIAF is starting off with a positive reputation.
Careful, the units with the T-Square with the motor on the end may or may not work with one piece windows ( for you unwinged ones). I just helped a bud to install the dolphin style and it works great on his vented truck. The cable drive units will allow the motor to be mounted lower or forward in the door. 6 of 1 and half dozen of the other I suppose. I seen the Autolock unit, and it looks fine for the price of 200 bonez. I stopped scroungin a few years back to save time and effort, so I can spend more time putting something together, not taking things apart.
Old 10-03-2005, 08:30 PM
mark914
mark914 is offline
thanks
Thanks for the responses and the ideas. I think i am going to take more of a look at whats around before i decide.
Mark
Old 04-30-2012, 04:32 PM
slowcruser
slowcruser is offline
slowcruser is starting off with a positive reputation.
Any other wrecking yard treasures???
I know new is better but has anyone have other wrecking yard power window regulators that will work in a 53 -55 F100?
I suspect a Crown Vic, Caravan or some other Mechanisms will work, but whats been tried? What power window regulators works?
Old 06-04-2012, 04:10 PM
slowcruser
Power windows on a one piece glass..
I found the answer to my own question in a MID FIFTY F100 PARTS catalog.
The power arm window regulators are to big if the vents are removed.They are fine to power windows if the vent windows are retained. But with the motor attached to the window regulator instead of a crank handel it is to big for small space.
Or another option is in the LMC catalog is a power drive that attaches inside
of the door over the existing hand crank handel shaft of the window regulator this unit drives the stock window regulator and will work with etheir a stock or one piece conversion and you can keep the manual crank.
The most popular is the removal of the window regulator and replacment with a vertical rail drive type. This is the type I was tring to avoid, bucause I want to turn the door access cover in to a storage pocket.
well thats my two cents....
Old 06-04-2012, 11:47 PM
AXracer's Avatar
AXracer
AXracer is offline
One solution, put you storage compartment on the outside of the door, either a pocket or a pouch. Which is more important, which will you use the most?
karjunkie
01-27-2015 07:26 PM
Perry55
05-25-2014 01:55 PM
ulev1st
18
03-13-2014 10:23 AM
ZZMAXX25
02-20-2011 10:58 AM
thrifty
13
05-03-2010 07:58 AM
Quick Reply: what power window kits you guys using? (53-56)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
