Electric fuel pump swap
Old 03-25-2019, 08:32 PM
7oldblue3's Avatar
7oldblue3
7oldblue3 is offline
I’m looking into replacing the mechanical fuel pump with an inline electric fuel pump but I was hoping someone might know what the flow rate should be on a 390. It only has a standard 2 bbl carb on it. Most inline pumps range from 20 to 50 gph but I can’t seem to find any info on the stock mechanical pumps. Any suggestions?
Old 03-26-2019, 01:18 AM
Ozzie H.'s Avatar
Ozzie H.
Ozzie H. is offline
The 1976 Ford truck shop manual says that the mechanical fuel pump on the 390 should be able to pump 1 pint in 20 seconds as a minimum; and the static pressure should be 5.0 to 7.0 P.S.I.
Old 03-26-2019, 05:46 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,108 Likes on 1,796 Posts
Why not stay with the stock pump?
Electric needs to be mounted close to the tank the inlet should be wet (below fuel level) as they do not pull fuel well.
Then the wiring. It needs to be run thru a relay so the pump gets full w 12 volts and a oil psi switch so when the motor is not running the pump will not run for safety. Motor catches fire or in a crash where you can not turn the truck off the pump will keep running putting gas on the fire!
Not cool in my book.
Eldebrock carbs like even lower than 5psi so you would need to deal with that too.
Dave - - - -
Old 03-26-2019, 06:00 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Why introduce hassle? Keep the mechanical pump.
Old 03-26-2019, 08:11 AM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
Electric fuel pumps with carburetors can be dangerous. A mechanical pump can supply plenty of fuel. NASCAR used mechanical pumps on their engines until they switched to fuel injection.
Old 03-26-2019, 08:56 AM
440 sixpack's Avatar
440 sixpack
440 sixpack is offline
Received 1,539 Likes on 1,131 Posts
Electric pumps are a cure for a problem that doesn't exist. just keep your mechanical pump.
1984oldn’slow
03-17-2019 03:40 PM
bigbird189
06-05-2016 11:49 AM
Merlin68F-100
02-25-2005 07:49 PM
SamD
1947 and Older Ford Trucks
03-21-2004 01:18 PM
Franklin2
06-28-2002 05:52 PM
Quick Reply: Electric fuel pump swap
