MajT
Old Jun 3, 2012 | 12:32 PM
MajT's Avatar
MajT
MajT
have a 1977 F-150, 4x4 with 79000+ miles on a factory rebuilt enginge. There is a slight oil drip coming from the bell housing inspection plate area. I also only have 10-15 lbs oil pressure at normal temperature idle. Is this indicative of a worn rear main oil seal? If it is, will "Bar's Rear Main Seal Repair" correct this problem?
Old Jun 3, 2012 | 01:01 PM
fmc400's Avatar
fmc400
MSEE
A rear main oil seal will not have any affect on oil pressure (unless the leak is so bad that oil is dumping out, obviously). 10-15 PSI at hot idle is just fine; the rule is 10 PSI per every 1000 RPM; so assuming your idle is at a decent speed, you're at about twice the minimum. The idiot light in the dash typically comes on at 5 to 7 PSI.
I don't recommend any sort of "stop leak" product. They rarely work, and often lead to other problems.
Old Jun 3, 2012 | 01:04 PM
79 f350ts's Avatar
79 f350ts
IMO stop leak products usually only cause money to leak from your pocket. replace the seal
Old Jun 3, 2012 | 01:16 PM
MajT's Avatar
MajT
Thanks guys for your quick reply. The leak is very minor. Cardboard on the floor will work for now.
MajT
Jun 3, 2012 01:03 PM
FishOnOne
Feb 14, 2008 09:48 AM
yankee88
Jan 19, 2004 05:05 PM
louis1234
Oct 5, 2003 08:28 AM
EceaRyder
Apr 30, 2003 05:36 PM
