On vacation 2 odd issues
Old Jun 3, 2012 | 09:09 AM
firedaniel's Avatar
firedaniel
Hey guys I'm curious your thoughts on these. I'm pulling a 9k lb camper on vacation with my family. The truck is running great but I have the abs light and a p0478 with check engine light on. We set up camp I cleared the codes and they have not come back on but I'm not towing. Any ideas? Is it something that can wait till I get back home?
Thanks
Dan
Old Jun 3, 2012 | 10:48 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Exhaust pressure control valve high input, ep is high for 30 seconds or longer; faulty ep sensor, vgt control valve slow to respond, stuck vgt valve. Do you have turbo farting? What year truck do you have. I printed a list of codes & have them in the glove box for future reference. exhaust pressure tube clogged or bad sensor?
Old Jun 3, 2012 | 11:15 AM
firedaniel's Avatar
firedaniel
It's a 06 f350. No turbo farts. Seems to run fine. It did come on after pulling a long steep grade. Maybe just need to clean the sensor?
Any idea why the abs light comes in while towing then clears after I drop the trailer?
Old Jun 3, 2012 | 01:29 PM
firedaniel's Avatar
firedaniel
Also curious I am running mat gearhead 8k. Should I try the unlimited tow or stock tune? Would that make a difference?
Old Jun 3, 2012 | 05:25 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I have those tunes, if you have a egt probe, you would know if you ok. The unlimted keeps the temp down, its just changes the shifting points. There is a tube the leeds to the exhaust pressure sensor. The sensor is under the thermostat housing. The thin steel tube runs down the drivers side exhaust maifold.
HKusp
Jul 30, 2021 04:44 PM
Shiloh51933
Oct 26, 2016 08:52 AM
diehardstroker
Feb 17, 2014 08:40 PM
4bigred
Aug 18, 2011 02:35 PM
fountain3520003
May 20, 2008 07:43 AM
