piston specs
Old Jun 3, 2012 | 07:42 AM
enriched&beyound's Avatar
enriched&beyound
Question piston specs
What are the specifications/ dimensions needed to do the swap to 351 pistons into 300 I6??
special rods needed to or will stock rods be fine?
just trying to get a mild rebuild done on ole 300.
thanks
Old Jun 3, 2012 | 12:53 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The rods will need to be bushed to fit the 351w piston pins, otherwise it depends on how much the block gets milled, etc.
Old Jun 3, 2012 | 07:39 PM
enriched&beyound
wasn't there certain years that they shared the same wrist pin?
Old Jun 3, 2012 | 07:49 PM
kas83's Avatar
kas83
I may be wrong, but I swore 390 pistons were a direct swap?
Old Jun 3, 2012 | 10:25 PM
BaronVonAutomatc
10-4, the early model rods are supposed to have the correct size rod ends for 351 pistons if you can find them. Not sure what years...
Old Jun 4, 2012 | 06:08 AM
enriched&beyound
Exactly my quandary...what years do I need to look at?
and if I do manage to find them, get them to clear everything, valves, head clearances...etc....will they take this 300 out of the realm of running on pump gas?
Old Jun 4, 2012 | 07:10 AM
BaronVonAutomatc
I wouldn't sweat finding early rods, it's no worry to have rods bushed to fit.
There are actually a ton more options for piston volume/compression height with a 351 piston, so whether or not it would run on pump gas depends on deck height, head volume, etc.
The_SnowMan710
Dec 3, 2008 03:33 PM
BaronVonAutomatc
25
Nov 14, 2007 11:07 AM
dazedrodeo
Jan 17, 2005 11:05 AM
RichardMaerz69
Feb 6, 2004 02:13 PM
St_alfonzospancakebreakfa
Oct 20, 2003 07:40 PM
