A/c evap removal?
Old Jun 2, 2012 | 08:16 PM
strokin83's Avatar
strokin83
A/c evap removal?
I've been having issues with my ac system not blowing much air. Today I decided to pull the blower fan and take a look. It looks to me as if the evap is completely packed full of dirt and won't allow air to flow through it well. So my question is: how hard is it to pull that thing out for cleaning? Does anyone know of a write up on this? Any help would be appreciated thanks. It looks like a booger.
Old Jun 2, 2012 | 10:36 PM
jedlane8870's Avatar
jedlane8870
I finally got mine clean through the blower motor opening, it took several tries with different cleaning solutions and compressed air. Turns out if you take the fender liner out its not that hard to get the whole housing out though.
Old Jun 2, 2012 | 11:11 PM
Yahiko's Avatar
Yahiko
Hi,
There is a product made for cleaning the evaporator. You should be
able to find this at a heating supply co. It mixes with water and
you spray that on and it foams up. They also have a spray can type.
It may cost more that way though. The stuff is really good for
dirty coils. Even if the compound does not make things clean the
first try it will soften the mud and make it easier to shop-vac it out.
Here is a link for a how to
Air Conditioners: How to Clean a Dirty Air Conditioning Cooling Coil or Evaporator Coil
BTW the stuff you want you will not find at Home Depot or Lowes
Granger would be a good place to look.
Sean
Old Jun 8, 2012 | 08:26 PM
strokin83's Avatar
strokin83
A little update. I pulled the fan and worked that evap over with a blower nozzle and a shop vac. Seems that's all I had to do she's good as new. The sad thing is I've been fighting this for a couple years. What a easy fix.
jmdub85
Jul 18, 2018 02:13 PM
Cyrusjohn
Dec 6, 2017 05:04 PM
materthegreater
Aug 27, 2012 07:53 AM
TinkerThinker
Jan 7, 2008 04:42 PM
DOUG5G
Aerostar
Jun 11, 2006 02:42 AM
