Cam/Exhaust Project
Cam/Exhaust Project
So, I'm finally getting around to doing long tubes. As the header bolts are gone, I was going to swap the heads to speed up the process to a weekend instead of waiting on a machine shop. While I'm doing all that, might as well do the cam and make it a full top end. Going with stock heads with some porting and Pace Setter 70-2221's, along with a flat tappet to save a bit of cash.
For a cam I was thinking Comp 35-255-5. I was going to get it with their small kit, which includes lifters and their timing chain set. So 2 questions:
-What do you guys think on the cam
-Does anyone know how it performs
-Mike
truck's in the sig. ('93 351w)
-Mike
That was my other cam choice, but ends up adding ~$150 to the final cost of the project. When you say more displacement, do you mean a 5.8 as compared to a 5.0, or more than 5.8? I'm assuming the latter (for now), but if not I might consider the 444232.
-Mike
Edit: Looking at the specs of the crane again, I noticed that it's bottom end RPM spec is 1400 RPM, 400 higher than the Comp. With the 5spd, I'm not sure if I'd want that, even if it puts out more power/future options. Also, there would effectively be no price difference. Also, do you know if the lifters it comes with will work with stock push rods? (I was planning to replace them anyways)
-Mike
on
Yes no problem.
ford347stroker
01-31-2014 12:05 AM
pkulaga
15
08-11-2005 05:50 AM
thunderguns71
13
05-20-2004 09:59 PM
