1997 ranger 2.3 overheating
Old Jun 1, 2012 | 09:19 PM
2002exPSD's Avatar
2002exPSD
Bought this truck at auction a few days ago. Started drive home and noticed temp gauge almost pegged full hot. Stopped and left it and pickup up later that day with trailer. Got home and started and ran it. Will not overheat at idle. Gauge fluctuates between full cold and 1/2 at idle. Rev up and temp drops to full cold. Drive around town under 35 and it stays between 1/2 and 3/4. Get on the highway and Pegs full hot. Replace thermostat and flushed system. Lots of rusty water and chunks of rust/mud poured out. Upper rad hose is firm and hot. Lower rad hose is warm soft. Bypassed heater core and still over heats. I can run water hose from top hole on radiator and water crosses threw radiator and pours out the bottom so I don't think it's clogged. It's not the head gasket, I have no smoke, no milky oil and no oil in coolant. Fan clutch seems fine, I can spin it with the engine off and feel resistance. Truck hasnt boiled over while running hot so the gauge may be wrong. I'm stumped and have no idea what else to do. If it means anything the truck runs very rough and pulled up a misfire on cylinder #1 and had a iac code.
Old Jun 1, 2012 | 09:56 PM
critterf1's Avatar
critterf1
Check for coolant in the #1 cylinder.
Old Jun 1, 2012 | 10:09 PM
2002exPSD's Avatar
2002exPSD
How do I do that?
Old Jun 1, 2012 | 11:12 PM
critterf1's Avatar
critterf1
Pull the spark plug and see if it's wet.
Old Jun 2, 2012 | 12:53 AM
michigan66's Avatar
michigan66
How many miles are on the truck? If miles > 100K, the impeller on the water pump may be worn/rusted down to the point that little coolant is circulating through the system. Under that condition, coolant may be circulating enough the handle the heat load with the engine idling or moderate speed but not enough to handle the heat load created at high speed.
Let us know what you find out when you pull the water pump.
Old Jun 2, 2012 | 06:22 AM
03 Maz B23's Avatar
03 Maz B23
Find the cause of your cylinder 1 issue and the overheating issue may disappear. Did you do a compression test? Did you check timing belt to see if the belt jumped a cog?
Old Jun 2, 2012 | 08:46 AM
srteach's Avatar
srteach
Too little cooling in the radiator can do what you are describing, and the flush having "chunks" in it point to partially clogged radiator. Pull the radiator and have it professionally cleaned and repaired. A good shop should do that for about $65 (my area) depending on how bad it is.
Old Jun 2, 2012 | 11:47 AM
critterf1's Avatar
critterf1
I say #1 plug is coolant fouled. (head gasket)
Old Jun 2, 2012 | 11:59 AM
2002exPSD's Avatar
2002exPSD
Truck has 162000 miles and the odometer still works( first ranger out of 4 that the odometer still worked).
Old Jun 2, 2012 | 12:38 PM
03 Maz B23's Avatar
03 Maz B23
I have a hunch you are correct. That or possible valve issues with that particular cylinder. A compression test would reveal one or both causes.
Old Jun 2, 2012 | 02:33 PM
2002exPSD's Avatar
2002exPSD
Sounds like low compression in one of the cylinders when I start it.
Old Jun 2, 2012 | 03:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is the coolant boiling over? How do you know the engine is really getting hot other than the factory idiot gauge?
Need to back up the gauge with an IR reading or another known good sender and gauge. I wouldn't take what the factory gauge is telling you as gospel.
Josh
Old Jun 2, 2012 | 10:27 PM
2002exPSD's Avatar
2002exPSD
Coolant is not boiling over but there is rusted water stains all over the engine compartment.
Old Jun 3, 2012 | 07:50 AM
critterf1's Avatar
critterf1
Have you pulled the plug yet?
Old Jun 3, 2012 | 02:10 PM
Bullitt390's Avatar
Bullitt390
Could have puked coolant at some point in time, but it still doesn't mean it is actually running hot now.
A bad sender with a wicked air bubble in the cooling system will cause the gauge to be erratic like a kitten on catnip.
Josh
