a/c woes
Old Jun 1, 2012 | 05:43 PM
teamlx88's Avatar
teamlx88
a/c woes
I have a 98 expy with 110k miles on it. I turned on the a/c last weekend and the air was only coming out of the vents "cool" . Not enough to beat the heat that day. So I popped the hood and checked the freon level and it was at full pressure and the compressor was running fine. When I felt the high pressure hose it was air temp and the return hose was so hot it burned my hand.
Do I have a clog? Or is it time for a new compressor? This truck is going to Florida this summer so I have to get this fixed asap. Thanks
Old Jun 2, 2012 | 01:55 PM
alloro's Avatar
alloro
What were the low and high side pressures readings when you checked them?
Old Jun 2, 2012 | 04:51 PM
critterf1's Avatar
critterf1
How did you "check" the refrigerant level?
Old Jun 2, 2012 | 09:37 PM
D-Cell_Mekanick's Avatar
D-Cell_Mekanick
Your orifice tube is plugged. Is your compressor short cycling? Do you have dual air, meaning front and rear? If so, might only have one tube plugged, and compressor will act normal. If that's the case is the air coming from the rear cold? What about the front air, is that what's cool?
Old Jun 4, 2012 | 10:08 PM
teamlx88's Avatar
teamlx88
I do not have rear air and the compressor is running normal. The high side pressure was 48 and I barely got a reading on the low side. I do not have a pro type a/c manifold guage setup, I am using a autozone type guage.
Old Jun 5, 2012 | 06:32 AM
projectSHO89's Avatar
projectSHO89
Either the compressor isn't "running fine" or your gauges are defective. Normal range readings should be 25-45 psi on the low side and 200-350 on the high side, depending on a variety of conditions.
Do NOT screw with touching the hoses coming off the compressor - you'll burn your fingers. Check the inlet and outlet hoses at the evaporator. The inlet hose should be very cold (30-40F). If the system is properly charged, the outlet line should be nearly the same temp. If the inlet is cold but the outlet is too warm, the system is undercharged and cooling performance will be poor.
You can tell that without any valid pressure readings based only on a sketchy description????? If the FOT were restricted or clogged, the compressor would be short-cycling.
Old Jun 5, 2012 | 08:25 AM
D-Cell_Mekanick
Sketchy description for sure. Correct the pump would be short cycling if it were plugged. With the readings the OP is giving, it sounds more like its low on refrigerant.
OP, find the orifice tube and see if the hose is hotter on one side of it than the other. I'd also find someone with a gauge manifold to see what the true readings are. Plus you will be able to see when the compressor is cycling and at what pressure.
If the system is low add some dye and refill. When it starts to blow warm again get out your black light and start looking for the leak.
dive2663225
Apr 18, 2018 10:00 AM
sittinguy
Aerostar
Aug 6, 2017 05:45 AM
4.9inline6
Aug 6, 2010 03:25 PM
rsulvan
Jul 6, 2006 02:33 PM
opportunitech
Aug 11, 2000 09:44 PM
