How are the rear vents connected? I can hear the blower running, but I don't feel air movement out of the vents.
The previous owner had a stereo installed somewhere in the rear (I found a power cable running back there). I'm wondering if something got disconnected when the audio equipment was removed.
Otherwise, is it a vacuum control from the **** that could be causing problems?
I have the same issue I think.
The head liner vents right behind the driver and passenger seats don't blow any air. Front air works fine, rear vents also work fine.
From what I understand the front headliner vents run off of the front ac ?
Where is this white blend door motor located ? I can't see the picture for some reason.
