turbo help please....
Old Jun 1, 2012 | 01:54 PM
bcaughhorn's Avatar
bcaughhorn
Short and simple. Is there supposed to be a o-ring or gasket between the turbo and spider?
Old Jun 1, 2012 | 01:58 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
O ring. Only gasket I know of on the 7.3 is the head gasket.
Old Jun 1, 2012 | 02:06 PM
bcaughhorn's Avatar
bcaughhorn
Ok. I didn't see 1 when I pulled the spider so I didn't put 1 back in. And at 65mph I get 2 psi of boost
Old Jun 1, 2012 | 02:07 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
YES, you can see the groove on the turbo outlet where it is supposed to be.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Jun 1, 2012 | 03:01 PM
CSIPSD's Avatar
CSIPSD
Then you need to look further...
Old Jun 1, 2012 | 03:12 PM
bcaughhorn's Avatar
bcaughhorn
I'm guessing I can order the o-ring from riffraff. Is this rite?
Old Jun 1, 2012 | 03:19 PM
CSIPSD's Avatar
CSIPSD
That is correct... Or right...
Riffraff Diesel: Garrett Compressor Housing Outlet O-ring 99.5-03
Old Jun 1, 2012 | 03:20 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
or you can order it from bob at diesel orings.....if you dont have his site bookmarked i would do so.......here is the link: #14-060 Turbo Compressor Outlet o-ring - Turbo and Related Items - 1999-2003 Ford 7.3L
Old Jun 1, 2012 | 03:21 PM
bcaughhorn's Avatar
bcaughhorn
OK. Thanks for the help.
Old Jun 1, 2012 | 06:06 PM
aawlberninf350
It's a Van Gogh
Sometimes ya just lay something shiny in the stream and you know a fish is going to hit it....
Sounds like the OP is done with this thread so I'll shamelessly hijack it. No offense taken if a mod makes my rantings go away.
Are there more gaskets on a 7.3? As a relative noob I'm genuinely curious. Seems like it's all o rings, loc-tite, gasolia and RTV. IMHO vc gaskets don't count since they are reusable forever, barring mishap. I'd say to qualify as a gasket in the traditional sense it would require replacement when disturbed, otherwise it's an ornate o ring that is intended to be reused.
Ah, IIRC the hpop has some gaskets involved that are not generally reused. So there's something. Maybe the oil cooler? Any others?
Old Jun 1, 2012 | 06:26 PM
Shake-N-Bake's Avatar
Shake-N-Bake
In my mind I've always figured there are 4 basic ways to seal stuff.
  1. machined surface to surface
  2. flexible sealers (RTV, Silicone etc)
  3. O-rings
  4. Gaskets
I think the 7.3 has all options in play. The lion's share seem to be O-rings which is helpful for maintenance since they can generally be re-used in many cases. Gaskets (by my own definition) generally aren't meant to be re-used so that may be why they aren't as common as O-rings on these engines. From memory there are a few that fall into the 'gasket' category....HPOP and Oil Cooler come to mind. I suppose the doughnut gaskets at the up-pipes qualify as well as the flat gasket at the dipstick flange fitting. I think there is a front cover gasket as well.... (I am probably forgetting a few others...)
I agree with you though...even though we call it a 'valve cover gasket' it's really an O-ring spacer gasket or maybe a combo 'O-ring/gasket/electrical pass thru' (if you will...)
Old Jun 1, 2012 | 06:42 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
My question is...how the heck oil didn't come pouring out of there? I blew one of the two orings in there and lost a gallon of oil on my way to work. Noticed the puddle when I parked it. Gut dropped!!
Old Jun 1, 2012 | 06:50 PM
bcaughhorn's Avatar
bcaughhorn
I ordered a new o-ring now
Old Jun 1, 2012 | 08:14 PM
bigb56's Avatar
bigb56
he means the o ring on the compessor outlet, not the pedestal
Old Jun 6, 2012 | 05:18 PM
bcaughhorn's Avatar
bcaughhorn
turned out it wasnt the o-ring. it was there and just fine. it was the idiot that pulled everything apart. he didnt get the spider and turbo lined up rite. so no seal.... im gonna have to talk to this idiot as soon as i see him. now i just gotta remember who it was
