code P2290
Old May 31, 2012 | 07:14 PM
DFLS's Avatar
DFLS
code P2290
I changed the ICP, no change in symptoms and code came back so I changed the pigtail. Still throws the 2290 code. Truck runs good until letting off throttle to coast or stop then it has the heavy black smoke / no power. Usually I just get going, let off on the throttle briefly and it returns to normal. Then back to smoke / no power again sometimes the next time I coast, sometimes lasts a few cycles. Happens mostly when towing (about 8000 lbs). Drove 40 miles city driving last week and had no problems at all. Hook on the trailer and the symptoms come back.
Could the new sensor be bad?
Can I remove the EGR valve, cover the hole and drive the truck??
Old May 31, 2012 | 07:55 PM
BLADE35's Avatar
BLADE35
the P2290 DTC isnt really a Bad ICP sensor code
OEM Oil FIlter??????????????????????????????????
Old May 31, 2012 | 08:00 PM
69cj's Avatar
69cj
And OEM cap??
Old May 31, 2012 | 08:04 PM
BLADE35's Avatar
BLADE35
Very Very Slim chance here^^^
NO^^^^^^^^^^
even if you could that wouldnt help a HPO problem
you can unplug egr valve when the trucks turned off so its in the closed position but again wont help a HPO issue
Fix the HPO problem then if it has a EGR Valve problem then address it
Old May 31, 2012 | 08:06 PM
BLADE35's Avatar
BLADE35
Originally Posted by 69cj
And OEM cap??
Thanks Mike thats what I ment
Keep an eye on me
Benchwrench's Avatar
Benchwrench
that's just one component for the mod, the other side has to be blocked off too.
check your vgt solenoid
Old May 31, 2012 | 09:02 PM
DFLS's Avatar
DFLS
And OEM cap??
yes all OEM and just changed all synthetic. (always every 5000)
Old May 31, 2012 | 09:03 PM
DFLS's Avatar
DFLS
So I wasted the $155 for the sensor and the $45 for the pigtail.
Old May 31, 2012 | 09:06 PM
DFLS's Avatar
DFLS
Don't know how to check this. I know where it is and I did clean the wire plug and wiggle the wires. Do I remove and see if it is sticking or moving freely, and clean it off?
Old May 31, 2012 | 11:02 PM
BLADE35's Avatar
BLADE35
Yes ^^^^^^^^the DTC/Code and symtoms returned and never got better
Plus you normaly would get a diffrent DTC for bad ICP sensor P2285
P2290 C O Injector Control Pressure Too Low Default inferred ICP is used, ICP is below desired pressure See diagnostic manual - ICP system.
I would deal with the P2290 DTC FIRST before you worrey about EGR Valves and VGT Silinoid/Turbo
Deal with what you Know is the Obvious problem P2290 Its a GIVEN
Your 110% shure Oil Filter CAP is OEM???????????
Odds are you have a HPO Leak
The First step to diagnos it is verify GOOD LPO Flow to oil filter housing by pulling the Filter out and hold the drain down inside filter housing with a screwdriver it should fill fast as someone cranks the engine over
You cant make HPO if the LPO side is Starving the HPOP
next would be an Air test of the HPO system or Pull IPR Valve and check for damageed screen on IPR
Old Jun 1, 2012 | 06:18 AM
npccpartsman's Avatar
npccpartsman
P2290 means that ICP desired pressure is above actual ICP pressure for X number of seconds while the truck is running. I'd pull the IPR valve and check it for a trashed screen. You could also have an STC fitting going bad. You need to find a way to monitor HPO pressure while driving.
Old Jun 1, 2012 | 06:36 PM
DFLS's Avatar
DFLS
Thanks npccpartsman and Blade
Looks like I have to look up/ learn a few acronyms and see what I am able to do myself...
I bought the truck used, the previous owner had the dealer do all the work including oil changes so as far as I know the cap is OEM.
I will try the drain test.
Could someone point me to the IPR? I'll try a search too.
Old Jun 1, 2012 | 06:56 PM
BLADE35's Avatar
BLADE35
ACRONYMS FORD
https://www.ford-trucks.com/forums/821641-acronyms.html
heres where your IPR is
But depending on year ICP maybe in passenger side valve cover but MY03 is ICP under turbo too
Old Jun 1, 2012 | 07:02 PM
BLADE35's Avatar
BLADE35
here is a GOOD READ
6.0L Bible Table of Contents
Check this out^^^^^^^^^All these pics come from here^^^^^
<TABLE border=0 cellSpacing=0 cellPadding=0 width=773 align=center height=1121 cool gridx="10" showgridx usegridx gridy="10" showgridy usegridy><TBODY><TR height=10><TD height=10 width=772 colSpan=5></TD><TD height=10 width=1><SPACER type="block" width="1" height="10"></TD></TR><TR height=30><TD height=1110 rowSpan=3 width=10></TD><TD height=30 vAlign=top width=200 colSpan=2 align=left content csheight="30" xpos="10">Return to Table of Contents</TD><TD height=30 width=562 colSpan=2></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1050><TD height=1050 vAlign=top width=762 colSpan=4 align=left xpos="10"></TD><TD height=1050 width=1><SPACER type="block" width="1" height="1050"></TD></TR><TR height=30><TD height=30 vAlign=top width=110 content csheight="30" xpos="10">Page 41</TD><TD height=30 width=550 colSpan=2></TD><TD height=30 vAlign=top width=102 content csheight="30" xpos="670">
Page 43
</TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1 cntrlrow><TD height=1 width=10><SPACER type="block" width="10" height="1"></TD><TD height=1 width=110><SPACER type="block" width="110" height="1"></TD><TD height=1 width=90><SPACER type="block" width="90" height="1"></TD><TD height=1 width=460><SPACER type="block" width="460" height="1"></TD><TD height=1 width=102><SPACER type="block" width="102" height="1"></TD><TD height=1 width=1></TD></TR></TBODY></TABLE>
<TABLE border=0 cellSpacing=0 cellPadding=0 width=821 align=center height=1601 cool gridx="10" showgridx usegridx gridy="10" showgridy usegridy><TBODY><TR height=10><TD height=10 width=820 colSpan=6></TD><TD height=10 width=1><SPACER type="block" width="1" height="10"></TD></TR><TR height=30><TD height=1590 rowSpan=3 width=10></TD><TD height=30 vAlign=top width=200 colSpan=2 align=left content csheight="30" xpos="10">Return to Table of Contents</TD><TD height=30 width=610 colSpan=3></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1050><TD height=1050 vAlign=top width=762 colSpan=4 align=left xpos="10"></TD><TD height=1560 rowSpan=2 width=48></TD><TD height=1050 width=1><SPACER type="block" width="1" height="1050"></TD></TR><TR height=510><TD height=510 vAlign=top width=100 content csheight="40" xpos="10">Page 10</TD><TD height=510 width=600 colSpan=2></TD><TD height=510 vAlign=top width=62 content csheight="40" xpos="710">Page 12</TD><TD height=510 width=1><SPACER type="block" width="1" height="510"></TD></TR><TR height=1 cntrlrow><TD height=1 width=10><SPACER type="block" width="10" height="1"></TD><TD height=1 width=100><SPACER type="block" width="100" height="1"></TD><TD height=1 width=100><SPACER type="block" width="100" height="1"></TD><TD height=1 width=500><SPACER type="block" width="500" height="1"></TD><TD height=1 width=62><SPACER type="block" width="62" height="1"></TD><TD height=1 width=48><SPACER type="block" width="48" height="1"></TD><TD height=1 width=1></TD></TR></TBODY></TABLE>
Old Jun 1, 2012 | 07:04 PM
DFLS's Avatar
DFLS
Thanks again --- I'll do what I can and report back.
