Squeaking when damp!
Old May 5, 2003 | 09:31 PM
RyGuy's Avatar
RyGuy
I have a 89 F-150 302 5.0. It seems when it is damp/humid that my fan belt squels like a pig. I have changed my belt, no luck, took my belt off and checked my tension arm pulley bearing, seem okay as far as a can see. What else could cause this??
Old May 6, 2003 | 02:46 AM
macguyver's Avatar
macguyver
You could try taking some fine sandpaper and scuffing up the pulleys where the belt rides. Sometimes the pulleys will get so glazed that even a new belt will slip.
Old May 6, 2003 | 03:28 AM
Racerdave's Avatar
Racerdave
hmm... have you used belt dressing latley? If you have ...... Take off the new belts, because belt dressing totaly messes them up. Buy new ones, then sand the pullys. NEVER EVER under any condition use Belt Dressing!!!!!! Very bad stuff... it works for about 1 hr.... then it makes things even worse... The only thing that it is good for is puting on rubber hose if it is stiff or old...
Old May 8, 2003 | 02:06 PM
No_BS's Avatar
No_BS
My '91 does the exact same thing. Most of the trucks made around that time do it. I don't think there is anything you can do accept live with it. It is annoying as hell though.
Old May 8, 2003 | 04:11 PM
pfogle's Avatar
pfogle
talk to the dealer there was an issue in the early 90s with the power steering pump pulley being like 1/32 of an inch off and making the belts squeak.
Old May 8, 2003 | 04:44 PM
TheWiz427's Avatar
TheWiz427
That worked for me! Mine was doing the same thing till i sanded the pulleys.
PMDRACER
Sep 18, 2013 01:08 PM
00GT
1983 - 2012 Ranger & B-Series
13
Jun 3, 2011 11:11 PM
JeremyJ
Mar 25, 2007 12:10 PM
eyeblion
1997 - 2003 F150
17
Dec 27, 2005 12:24 PM
91Van
29
Oct 13, 2003 09:36 AM
