Some more help pleae !!
Old May 31, 2012 | 05:32 AM
94TransAm's Avatar
94TransAm
Well i'm marching on with Rays F1 pickup, got the booster kit and pedal assembly installed now i'm stuck again. It seems the calipers in the kit from CCP have no banjo bolts for the calipers so there's a hiccup.
The master cylinder comes with no brake fittings at all, and here's where i need help, the kit is pictured below.
1 Does anyone know what calipers these are, ie Mustang 2 ?
2 The master cylinder, it has 2 outlets on the left side [viewed from the front] these fittings are almost a centimeter across, can you get fittings that size or is there a reducer and what size thread are they?
3 I can see the rear brakes are fed from the compensator attached to the unit, but which do i use for front left and right or does it not matter?
4 What size fitting goes into the front brake hose?
5 I take it i can use 3\8ths brake pipe which is readily available here?
I'm hoping you guys who helped me out before can bare with me as the only fittings available here seem to be all metric no-ones stocking the old imperial sizes.
Old May 31, 2012 | 06:22 AM
4tl8ford's Avatar
4tl8ford
Your best bet is to contact CCP and see what the provide - Unless someone bought the same kit you will be getting a bunch of guesses
Old May 31, 2012 | 06:30 AM
94TransAm's Avatar
94TransAm
I did wonder about that, i was just hoping someone had !
Old May 31, 2012 | 06:43 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Those look like GM calipers like found on mid-70s Chevelles. I used a similar kit once and it required 73-77 Chevelle calipers. The banjo fittings are pretty universal for GM calipers from the late 60s to the early 80s...
Old May 31, 2012 | 08:18 AM
94TransAm's Avatar
94TransAm
Thanks, that helps with the calipers, keep that help coming !
Old May 31, 2012 | 08:49 AM
AXracer's Avatar
AXracer
3/8" would be huge for brake lines, that's fuel line size, did you mean 3/16"?
Old May 31, 2012 | 09:42 AM
94TransAm's Avatar
94TransAm
Ooops yeh 3\16 got the 2 mixed up, doh.
vonhef
Jun 24, 2018 08:02 AM
Tomget
Sep 25, 2017 02:31 PM
Madrid1214
Jul 21, 2015 12:52 PM
NateTheGreat
Jan 6, 2015 07:38 PM
94TransAm
Jun 10, 2012 01:13 PM
