Axle Codes
May 30, 2012 | 06:07 PM
Axle Codes
The axle code on my '74 is 24P. The code on my '76 is 24J. What do these mean?
May 30, 2012 | 06:32 PM
May 30, 2012 | 06:37 PM
Go over to
www.Fordification.net and decode them.
IIRC, if it's 2WD and the third position of the code is a J that it means the rig came equipped with power steering. For a 4WD, the third position denotes the axle model and rating.
May 30, 2012 | 08:17 PM
Does anybody know how many spline axles the '74 F250 4X4 would have?
May 30, 2012 | 08:57 PM
Front: 30 spline inners, 19 spline outers.
Rear: 16 spline (30 spline after late year '75).
May 30, 2012 | 09:26 PM
Quote:
Originally Posted by
montana_highboy
What are the inners and outers?
I have my eye on a Dana 60 with a posi in it out of a '72 F250 for $300. Is it worth that?
May 30, 2012 | 09:40 PM
1972RedNeck
An axle shaft has two ends... and they are correspondingly splined different.
May 30, 2012 | 11:33 PM
1972RedNeck
The fronts are 2 piece shafts on either side of the axle, hence the terminology inners and outers.
The D60, if also a '72 will only be 16 spline, so it's worth far less than $300 if that's the case.
lynn s 460
May 3, 2010 08:27 PM
ctrain22
Oct 31, 2007 02:15 AM
factory594x4
Jan 26, 2007 07:39 PM
MadManThumper
Mar 28, 2003 09:16 AM
09 ,
1964 ,
19731979 ,
24 ,
axel ,
axle ,
code ,
codes ,
f100 ,
ford ,
rear ,
truck
