Brake Pins
Old May 30, 2012 | 11:36 AM
hammer65's Avatar
hammer65
Brake Pins
I decided after reading on here, that I probably should check my Brake pins.
So this A.M. I picked up some pin lube and pulled the left front. Ahhh !!!!
New style pins, a little dirty, but cleaned up nicely. PO must have changed them. Lubed up and reinstalled.
I gave some thought on quitting there, since it had the new style,but I pulled it anyway. Top pin frozen almost solid. Turn and twist with pliers and drive with drift, turn again and drive etc. Finally came out. bottom came out OK. Both were new style pins. New top pin and cleaned bore, and reinstalled.
I got too hot, so I am waiting until a little cooler to pull the rears.
My point is that it seems as though the NEW STYLE PINS can freeze also.
Old May 30, 2012 | 11:49 AM
riverrat41's Avatar
riverrat41
You bet they can.They still need to be checked and lubed periodically.Good Job!
XLnAK
Oct 21, 2014 07:10 PM
FordTruckfan89
Nov 3, 2013 05:55 PM
bjr23
Oct 11, 2008 09:05 AM
DR JOE
Feb 21, 2008 12:30 PM
Ed in Maine
May 4, 2007 11:19 AM
