X code for Boost?
Old May 29, 2012 | 11:19 PM
uofmgriz's Avatar
uofmgriz
X code for Boost?
just checked the library of x-codes that I got off of here for my SGII, however, I didn't see one specifically for boost...is there one and if so could I please get it. I have the one for the VGT already and have been watching that...everything normal...thanks
Old May 29, 2012 | 11:27 PM
RPM371's Avatar
RPM371
Boost
TXD 07E0221440
RXF 046285140640
RXD 3010
MTH 001D0050XXXX
NAME BST
Notes XXXX = See Table
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
Old May 29, 2012 | 11:34 PM
uofmgriz's Avatar
uofmgriz
Originally Posted by RPM371
Boost
TXD 07E0221440
RXF 046285140640
RXD 3010
MTH 001D0050XXXX
NAME BST
Thanks...I appreciate that...will be hitting up that website here directly to make sure there aren't any others out there "looming"!
Old May 30, 2012 | 05:27 AM
npccpartsman's Avatar
npccpartsman
Scan gauge inputs: ScanGauge II XGauge codes - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum
FORD 6.0 L Diesel:
GAUGE TXD RXF RXD MTH NAME
FL 07E02216C1 0462451606C1 3010 000101480000 Fuel Level
VRF 07E0221155 046205110655 3010 006433330000 VREF (CALIBRATION VOLTAGE INPUT)
BAT 07E0221172 046205110672 3008 000100010000 BATTERY VOLTAGE
ECT 07E0221139 046205110639 3008 000200010000 ECT Degrees F
EOT 07E0221310 046245130610 3010 00090005F060 EOT Degrees F
TFT 07E1221674 046205160674 3010 000100080000 TFT Degrees F
IAT1 07E0221123 046205110623 3010 000100010000 IAT1 Degrees F
IAT2 07E02216A8 0462051606A8 3010 000100010000 IAT2 DEGREES F
MAT 07E02216E0 0462051606E0 3010 001200050020 Manifold Air Temperature (*F)
ICP 07E0221446 046205140646 3010 003900640000 ICP PSI
ICV 07E02216AD 0462451606AD 3010 004827100000 ICP voltage
IPR DC% 07E0221434 046285140634 3008 0DCA03E8000A IPR %
INJPW 07E0221410 046245140610 3010 044C04E2FFF1 FPW Microseconds (table)
INJPW 07E0221410 046205140610 3010 000800010000 FPW Microseconds (modified)
ITM 07E02209CC 0426850906CC 3010 000A00400000 INJECTOR TIMING BTDC (DEGREES)
MFD 07E0221412 046245140612 3010 006400100000 MFDES Mg per Stroke
MFD 07E0221412 046245140612 3010 000100100000 MFDES (ALT)
VFDES 07E0221411 046245140611 3010 006400100000 VFD Cubic mm
FMP 07E02209D0 0462450906D0 3010 006401000000 FICM Main Power (Volts 47-48)
FVP 07E02209CE 0462450906CE 3010 006401000000 FICM VEHICLE POWER (SHOULD BE 12 VOLTS)
FLP 07E02209EF 0462450906CF 3010 006401000000 FICM LOGIC POWER (SHOULD BE 12 VOLTS)
FSN 07E02209CD 0462050906CD 3601 000100010000 FICM-sync 0=NO, 1=Yes
SYC 07E02209CD 0462050906CD 3000 000100010000 SYC CAM/CRANK POSITION SENSOR SYNC (1= IN SYNC)
SYC 07E02209CD 0462050906CD 3001 000100010000 SYC ALTERNATE
SYC 07E02209CD 0462050906CD 3701 000100010000 SYC ALTERNATE
FSS 07E022099F 04620509069F 3010 000100040000 FAN SPEED SENSOR
FDC 07E022091F 04624509061F 3010 013103E80000 FAN SPEED DUTY CYCLE
Baro 07E0221127 046285110627 3008 003100500000 BAR Inches of Mercury
EBP 07E0221445 046285140645 3010 001D00500000 EBP PSI
EBP 07E0221445 046285140645 3010 001D0050FFFB EBP (-0.5 PSI)
BST 07E0221440 046285140640 3010 01220320???? PSI/BST MAP Modified signal PLUG IN VALUE FROM TABLE FROM YOUR MAP
MAP 07E0221440 046285140640 3010 012203200000 MAP EXTENDED RANGE
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Old May 30, 2012 | 10:15 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You can add more to the table for higher elevations:
12.7 FF81
12.8 FF80
12.9 FF7F
13.0 FF7E
13.1 FF7D
13.2 FF7C
13.3 FF7B
13.4 FF7A
13.5 FF79
13.6 FF78
13.7 FF77
13.8 FF76
13.9 FF75
Although, Texas wont need those!
Old May 30, 2012 | 02:23 PM
uofmgriz's Avatar
uofmgriz
I hope I'm not here any longer than I have to be...15 years has been 13 years longer than I wanted, however, jobs pay better down here than back home...Montana. Thanks for the list. I put them on my Evernote app on my phone (it auto-syncs with my laptop)
1964 f100
May 18, 2014 08:10 PM
Yahiko
Apr 1, 2013 07:16 PM
hott-rodd
Aug 23, 2011 05:42 PM
JonArmy
Aug 22, 2011 04:11 AM
onuredneck707
Jul 20, 2011 05:04 PM
