Bronco II Ford Bronco II
Black smoke???
Old May 5, 2003 | 04:14 PM
AbadDriver's Avatar
AbadDriver
Black smoke???
Yesterday my truck started acting up, bouncing idle and black smoke. when stopped she wants to stall. ive checked the Fuel pressure reguator, and fuel filter. the part that gets me is it ran fine for the long drive(40 miles) that night, then in the morning she didnt want to act right. ANy Ideas?????
Tim
Old May 5, 2003 | 08:41 PM
Ken00's Avatar
Ken00
Black smoke???
When you say you checked the FPR, did you check for a leaking diaphragm? I would also pull the codes to see if the ECU is picking up a bad O2 senser. Also check the O2 wiring, it is common for the wires to get burned.
Old May 6, 2003 | 06:01 AM
AbadDriver's Avatar
AbadDriver
Black smoke???
Where exactly is the O2 sensor located? i have my truck garaged so i can attempt to fix it. Btw it doesnt usually start blowing black smoke till after it warms up.
Thx for the help
Tim
Old May 6, 2003 | 10:02 AM
Ken00's Avatar
Ken00
Black smoke???
Since your in the BII forum I would expect you to have a 2.9L in it but I don't see a BII listed in your signature. On a 2.9L it should be on the passengers side exhaust just after it drops down from the manifold, top side of the pipe. Since it happens after is gets warm I would suspect a sensor problem since that is when it goes into closed loop. Try pulling the codes, both key on engine off and key on engine on, they should point you to the problem.
BroncoEx
6.4L Power Stroke Diesel
Aug 25, 2013 08:02 PM
Towster
Aug 31, 2011 09:09 PM
whitesdford
16
Oct 12, 2009 12:27 AM
Don Tim
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 22, 2007 07:22 AM
gumboluvr
Jul 31, 2006 10:19 AM
