im doing the manual swap on my 1991 f350 2wd crew cab 8 foot box diesel.
the shaft SUPOSEDLY for my truck that a guy dropped off is approx 42 inches for the front (center of U joint to center of hangar bearing) which seems in spec, has a 14" "slip yoke" at minimum spline engagement (when all splines are just inside the rear shaft), but my worry is..the rear shaft is only 40 inches u joint to u joint.
can someone please tell me the length of their rear driveshaft for their crew cab long box manual truck please!?
