needin help
Old May 27, 2012 | 10:37 AM
weder's Avatar
weder
needin help
I have a 87 f-250 with 6.9 and it overheated and now it turns overreally slow and will not start. I replaced the starter and ground cables and even loosened the belts and still nothing.. any ideas?? I would sure appreciate it..
Old May 27, 2012 | 10:49 AM
johnboggs21's Avatar
johnboggs21
I would put a bar on the engine and see how hard it is to turn over by hand. Im afraid you might have toasted some bearings or something
Old May 27, 2012 | 11:45 AM
joe f350's Avatar
joe f350
how hot did u get and for how long
Old May 27, 2012 | 12:18 PM
weder's Avatar
weder
I was affraid of something like that really.. the gauge doesn't work right. Iy didnt even say it was hot.. it did die on its oen though.. i tried to pull start it and the ground wire was smoking so i thought that was it.. ill try the bar after lunch and let y'all know..
Old May 27, 2012 | 01:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
sorry to hear.
spend the few bucks on a real temp gauge for the replacement engine,so you can shut her down and let it sit if need be,and or push,tow,drive a bit then stop and let cool,whatever it takes to avoid going past 240 for any length of time until you can fix the issue.gauges are cheaper than engines.
not trying to pour salt on a wound.just helping for the next time.good thing is,used idi's can be found fairly cheap.500$ or less generally.
Old May 27, 2012 | 04:40 PM
weder's Avatar
weder
The gauge seemed fine until that pointit showed normal while i sat on the side of the road..
chubrock108
22
Sep 3, 2010 07:51 PM
tommyuscg
Aug 9, 2006 10:10 AM
MelSears
Sep 1, 2004 11:18 PM
kermit
Aug 30, 2004 03:49 PM
jrv
Electrical Systems/Wiring
Jun 26, 2004 11:31 AM
