Best timing Chain? Mild Modifications? 400
What is the best timing chain for a 75 400 My timing chain just got stretched...... it is definatly a stock one i think... one day i got mad and mashed the gas and it stretched my chain by 5 degrees.
so instead of 10 degree before top dead center it is now, 15 degrees.
I intend on putting something that can take a pretty good amount of stress without stetching.
looking to spend about 100 dollars total for the whole works timing chain and gears.
I don't understand.....this is pretty much a good quality product, readily available (even at a local part stores/machine shops) & been around for 50+ years.....excellent for street/strip applications, chain only or chain/gears availability.....your gears should be fine, so I would just go for a chain...
Uhh, pardon me but NO! NO NO NO NO NO! The timing set gets replaced as a set. No new chain on old gears. You have to pull the whole thing to put the chain back on anyway, why in the world would you go through all that labor and then put the old parts back on?
These will allow advance, zero or retarded timing in most cases. The OEM replacement will have the cam 4 degrees retarded for engines '72 and later iirc. Zero is what you want, helps a little in the power and economy department:
6.6L/400 - Cloyes Gear - Timing Chain and Gear Sets - FORD - Camshafts & Valvetrain - Engines & Components - SummitRacing.com
Uhh, pardon me but NO! NO NO NO NO NO! why in the world would you go through all that labor and then put the old parts back on?
OP has a stocker with a stretched chain. Is there any doubt there is wear in the gears? The money here is the labor. $60 for the set, $100 if he goes fancy. That's for all three, imo, the only way timing sets should be replaced. Sure, if you have a double roller with low miles in a race motor, you might just swap in a new chain. But in this case, it's all three.
And yes, I'm sure dealers would do the minimum on this job and cheat the customer--probably charge for all three parts and replace just the chain when they could get away with it.
Again, imo, there is quite a difference between transmission gears vs. timing set gears.
X2 on changing the whole shebang. You have it opened up anyway. I use the Rollmaster chain and gears. It's a dbl roller with a timkin bearing machined into the cam side of the big gear and it is a direct replacement for the stock one to. I believe it's about 60-70$ BUT ..... IMHO one of the best investments you can make. Popa John
X3 on the whole thing. Have a look at 351C timing sets on aussie evilbay. you can pay nearly 2 hundy if you really wanted, but they come right back down onder a hundred and readily available everywhere
Why, because unless there is something wrong with the gears, that's the way it has been done for about 50 years including dealerships! No different than a tranmission, if the gears meet spec, there is no rewson to change them- only the syncro's, pins, shims, etc. Now if you have a question about the gears (as I stated), then yes, replace them as well as a kit.
x4 with them sorry
stock stuff and performance parts do not mix when it comes to that area that's like mixing a edlebrock chain with old gears that could be ready to break clean off.
The forged parts must match for the fact it could cause catastrophic damage to the engine if the gears so happen to strip or the chain breaks.
I didn't think you could only just buy a chain ? Never been that cheep
. Even if you could, one would have to wonder if the new chains rollers would match up to the old gears cogs ? Not worth taking a chance, any chain and gears I ever took out the cogs were worn as well. Get some sun screen and a parasol, I think that So Ca. beach sun is getting to you !
x4 with them sorry
for non-damaged oem replacement parts, a simple chain replacement will be fine. There is nothing wrong with replacing the gears as well if you want to, but replacing gears that are not damaged, have no unusual wear patterns, chances are the oem gears that are likely currently installed are of a better quality that the replacement ones (even if you go name brand to name brand)..but this is all part of the teardown assessment. It's kinda like deciding you need to repace the tranny/diff gears for a rebuild, before you even look at them....nothing more, nothing less.
. Even if you could, one would have to wonder if the new chains rollers would match up to the old gears cogs ? Not worth taking a chance, any chain and gears I ever took out the cogs were worn as well. Get some sun screen and a parasol, I think that So Ca. beach sun is getting to you !OP has a stocker with a stretched chain. Is there any doubt there is wear in the gears? The money here is the labor. $60 for the set, $100 if he goes fancy. That's for all three, imo, the only way timing sets should be replaced. Sure, if you have a double roller with low miles in a race motor, you might just swap in a new chain. But in this case, it's all three.
20$ @ Orielly's
Cloyes - Timing Set
Part Number: C3005K
Line: CLO
Limited Lifetime Warranty
UPC: 750385800053
Includes: Crank Sprocket, Cam Sprocket And Chain
Quantity Per Vehicle: 1
Detailed Description
Sprockets Are Made From High Alloy Steel, And Heat-Treated For Durability. Chain Is Pre-Stressed And Heat-Treated For Longevity.
Manufacturer Information
Cloyes timing components offer the most complete coverage in the Aftermarket for Domestic cars, light trucks and Asian cars, light trucks. Cloyes timing components meet or exceed OE standards and in many applications are the same product that is in the OE engine.
Part Number: C3005K
Line: CLO
UPC: 750385800053
