9" ford differential
Old May 26, 2012 | 07:47 PM
TDean's Avatar
TDean
Is this a trac lok differential?[IMG][/IMG]
Old May 26, 2012 | 10:19 PM
PatsPOS's Avatar
PatsPOS
Looks like an open diff from my POV.
Pat
Old May 26, 2012 | 10:52 PM
TDean's Avatar
TDean
Both axles spin at the same time.
Pat
Old May 27, 2012 | 01:11 AM
xlt4wd90's Avatar
xlt4wd90
Without load, both axles of an open differential will turn together.
Look at the female splines on each side of the differential assembly. The splines on one side of a LSD are in two pieces, one inboard of the other. One of those is connected to the clutch carrier.
Here's another test: Try holding both the housing and one axle steady, and turn the other axle. If you can easily spin it and the pinion, it's either open or has really worn clutches. Ford's standard spec for the preload torque on the clutches is about 40 lbf-ft.
Old May 27, 2012 | 08:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You be the judge: https://www.google.com/#hl=en&gs_nf=...w=1280&bih=596
Old May 27, 2012 | 10:21 AM
TDean's Avatar
TDean
Do open carriers have springs in them?
Old May 27, 2012 | 10:58 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Not that I know of, but not my area of experience.
Old May 27, 2012 | 11:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the AXLE code stamped on the Warranty Plate (1959 thru 1980), printed on the Certification Label (1981 thru today) begins with a letter: Limited Slip.
If the AXLE code begins with a number: no Limited Slip.
9 inch: Misc 1957/80 Passenger Cars / 1957/83 F100 / 1965/67 E100 Super Van / 1966/86 Bronco / 1969/74 E200 / 1975/86 F150 & E100/150.
Some of the above 1983/86's have the 8.8" integral, some have the 9" as it depended on the applications.
Some 1959/68 F100's have optional Dana 44's with Limited Slip. Some 1977/79 F100/150's have Dana 44's with/without Limited Slip.
Some 1963/69 F100's have optional Dana 60.2's and Dana 60.3's, both w/Limited Slip. These two Dana's are not the same as a Dana 60.
Old May 27, 2012 | 02:23 PM
TDean's Avatar
TDean
This appears to be the same thing. Looks like whatever it is, not very popular.
HELP identifying a 9 inch "posi" - Ford Muscle Forums : Ford Muscle Cars Tech Forum
Old May 27, 2012 | 03:08 PM
NumberDummy
(sigh) Posi or Positraction are strictly GM terms. One would think a Ford related forum would know this.
Old May 27, 2012 | 03:20 PM
TDean's Avatar
TDean
He has one post. Anyway, got it narrowed down to possibly an early auburn unit. I know now, it is not an open differential.
Old May 27, 2012 | 03:31 PM
NumberDummy
The only Auburn unit I'm aware of is this:
In 1935, Auburn introduced the two speed Columbia rear end. Auburn and Columbia were owned by Errat Lobban Cord, who also owned Lycoming and Duesenberg. The FWD Cord L-29 was available 1929/32, 'Coffin nosed' Cord 810/812 in 1936/37.
Ford offered the Columbia as an option in 1940/48 Passenger Cars. This unit is vacuum operated. hit the dash mounted switch, a screech is heard from the rear end when it changes gears.
Old May 27, 2012 | 07:48 PM
xlt4wd90's Avatar
xlt4wd90
Auburn LSDs use a cone-type clutch, so it's going to look different from Ford's Traction-Lok. I've never actually seen one apart, so I don't know what it looks like. However, I know that once its clutch wears out, it's not a simple matter of replacing clutch plates as in the Fords. I think the entire differential assembly needs to be replaced, or you have just an open differential.
And I agree with Bill; I've seen a lot of people incorrectly refer to Ford's LSDs as "Posi". Brainwashed by the mighty GM corp.
FORDF250HDXLT
28
Apr 8, 2024 07:23 AM
RojoStar
Aerostar
23
Sep 20, 2012 12:09 PM
rollthecoal
Offroad & 4x4
Sep 15, 2012 11:12 PM
quadzjr
Offroad & 4x4
20
Mar 20, 2008 03:50 PM
quadzjr
Offroad & 4x4
Jan 9, 2008 07:13 PM
