I'm on the side of the road, broke down on my phone. We were on our way to pick up a pizza doing sixty when my truck just quit. I felt the engine give out and no power. I put it in neutral and the rpms dropped to 0 so I suspect the transmission was keeping the engine going for a few seconds. Any ideas guys before I have to be towed??
I un plugged the fuel bowl heater. My truck is an 02, do you think itd be the the same fuse? And is there a fuse i can pull to replace it for a quick fix?
The fuse was burnt, so i replaced it with my adjustable pedals one. Still didnt start. the tach does not move when trying to start, which tells me the cps is bad as well?
My glow plug light comes on as usual, everything seems fine except for the tach. I cant recall if my tach moved till it started anyway? Its an 02 and i thought in 02 they stopped that from moving anyway? Or was it the older ones that dont move. Im on my way to get a cps right now and cross my fingers.
